Who has had it done? and how do you like it? is it necessary? I'm thinking of having it done to my Pionner Pro1140HD Best Buy is doing calibrations for $300. I checked around and that's a good price. They sent some of their installers back east to get (ISF Certified) They had two Samsung LCD's side by side one calibrated the other on standard and of course I played with the un-calibrated display to see if I could make it look as good as the calibrated display and I could not. The detail was much superior on the calibrated display.
I called Pioneer to see if it was necessary and would it make the picture better and their response was yes if your not going to change your room around. Colors, light, furniture and objects can effect the calibration settings it would have to be re-calibrated if I made any major changes in the room including paint.
I assume its more for a person that has a dedicated home theater room where changes to the room are not made often.
What do ya think?
What do ya think?
