Tom Nousaine data list update(svs)
  • P-Dub
    Office Moderator
    • 6766
    Taken entirely from here
    I havent got MY issue yet(damn post office ),but I've received email from reputable sources that they have gotten their issue of the SENSIBLE SOUND ...included in this issue is the Tom Nousaine review of the 20-39cs(we sent him a dual 39 package, but he choose to simply meausure one tube, and indicated you'd get a 6dB increase across the board with both tubes powered up).
    NOTE:the SVS data is with the full(both passive cylinders+600w amp)package operating.
    All figures are for a corner loaded subwoofer, 2 meter SPL mic distance,10%
    distortion limit,and the SPLs have been averaged from the maximum output at
    1/3 spacing at 25/31/40/50/63hz.
    ( * ) denotes a manual data adjustment applied by myself to compensate the
    subwoofer from Nousaine's *small* room(2400) to his newer *large* room(7500).
    SVS Dual 20-39cs+600w amp 115.5 /20hz~97 / 25hz ~111.8 / 31hz ~120.9(124dB peaks)
    STRYKE HE15 proto-type 115.3 / 16hz~99 / 25hz~106
    VELODYNE F1800 - 111.9
    SVS 20-39cs - 109.5 / 20hz~91dB / 25hz~105.8dB
    VELODYNE FSR15 - 109.1 / 16hz~90.1 / 25hz~103.1
    MISSION 700as - 108.1 / 25hz~102
    Paradigm PW2200 - 108 / 20hz~84 / 25hz ~104dB (112.8dB peak)
    VELODYNE HGS15 - 107.7 / 16hz~89.1 25hz~102.1dB
    Paradigm Servo15 - 107.3 / 27hz
    VELODYNE SPL12 - 107.1 / 20hz ~90 /25hz ~ 99
    HSU RESEARCH TN25(w/250w) - 107.1 / 30hz
    HSU RESEARCH VTF-2 - 107.1 / 20hz~9325hz~99dB
    Cerwin Vega cvt300s - 107 / 16hz~80db / 20hz~92(112.4dB peak)
    KLIPSCH KSW300 - 106.0 / 25hz~92 *
    Cerwin Vega LW12 - 106.0 / 20hz~89
    POLK 650 -105.9 / 25hz~90
    Infinity 1.2s - 105.5 / 20hz ~90 / 25hz~95
    BW asw1000 - 105.4 / 25hz~92.4 *
    MK mx125 mkII - 105.3 / 20hz 89 / 25hz 95
    VELODYNE ct150 - 105.3 / 20hz~82(111.4dB peak)
    JBL D112 - 105.2 / 25hz~95
    KLIPSCH KSW12 - 104.9 / 25hz~90
    Boston Acoustics PV800 - 104.4 / 20hz~85
    Phase Technology PC500(towers) - 103.6
    Infinity interlude100 - 103.5 / 25hz ~ 94
    BW asw2000 - 103 / 29hz *
    PSB Subsonic6 - 102.7 / 25hz~94
    Sound Dynamics rts1200 - 102.1 / 25hz~92(110.9dB peak)
    Infinity IL100s - 102dB / 25hz ~94dB
    VELODYNE ct120 - 101 / 20hz~87
    MK - mx105 -100.6 / 25hz~86
    ATLANTIC TECH 272 PBM - 100.5 / 20hz~85
    INFINITY hps250 - 100.2 / 25hz~82(112.8dB peak)
    KLIPSCH LF10 - 100.1 / 25hz~90
    PSB subsonic 3i - 100 / 28hz *
    MISSION ms70asa - 100/32hz~92dB
    SUNFIRE Jr. - 100 / 25hz~95
    VELODYNE VLF810 - 100 / 25hz~91
    Canbridge - 100 / 20hz ~82dB
    POLK PSW350 - 99.8 / 25hz~82
    VELODYNE FSR12 - 99.7 / 20hz
    JAMO E 8sub - 99 / 25hz~ 86dB
    VELODYNE VA1012 - 99 / 29hz
    JBL PB10 - 99 / 25hz 82
    POLK RMDS-1 - 98.6 / 25hz- 77
    VELODYNE FSR10 - 98.4 / 20hz
    BW asw2500 - 98 / 25hz~86dB
    ENERGY ES12xl - 98 / 28hz *
    Paradigm PDR10 - 98 / 25hz
    PHASE tech power8 - 98 / 25hz~84
    Polk psw250 - 97.3 / 32hz~91
    ATHENA S3 - 97.0 / 25hz~87
    Energy S8.2 - 97 / 25hz ~82
    VELODYNE CT80 - 97.0 / 25hz~81
    MIRAGE frx s10 - 97 / 25hz~84
    JAMO sw505 - 97
    Klispch KSW10 - 96.9 / 25hz~85
    TANNOY PS110 - 96.8 / 20hz~71 / 25hz~84
    CANTON AS25 - 96.8 / 25hz~80
    MK V-1250thx - 96 / 25hz~86
    Atlantic technology 4.5 - 96 / 25hz~82
    ATHENA S2 - 96 / 25hz~87
    ACI titan - 96dB / 25hz~80
    PSB alphasubzero - 95.2 / 32hz~88
    Aura Lss-107A - 95.2 / 25hz~73
    Celestion cswII - 95 / 25hz~78
    Paradigm 90P(towers) - 95 / 20hz
    GALLO MPS-150 - 95.0 / 25hz~86
    ENERGY ENCORE - 94.4 / 25hz~78
    ENERGY XL8 - 94 / 25hz~78
    POLK PS-120 - 94 / 32hz -no SPL given
    Wharfedale Modus - 93.1dB
    DEF TECH BP2002TL Tower - 92.3 / 25hz ~80(single tower)
    Paradigm PD8 91.4 / 25hz~73dB
    MK k9 - 90.1 / 25hz~77
    Cerwin Vega hts15 - 89 (107 from 40-100hz) / 39hz
    DEF TECH Pro Tower400 - 89 / 25hz~81d (single tower)
    DEF TECH BP 2006TL Tower - 88.4 / 25hz ~73(single tower)
    ATHENA P1 88.5/ 32hz~85.5
    -----------the following use a 25-50hz range----------
    Boston Acoustics VR2000 -109dB
    Hsu Research 12V (150w) -106.5dB / 25hz - no SPL given
    Cerwin Vega HT-PWR12 -105.9dB / 25hz - no SPL given
    BW asw800 -105.1dB / 26hz - no SPL given
    Klipsch SW12 series2 -104.6dB ~(32-50hz) / 32hz - no SPL given
    ADS ms3 -104dB
    Phase Technology 1.0 Octave -103.3dB / 25hz -no SPL given
    Velodyne VA-1215x -102.6dB / 25hz - no SPL given
    BAGEND 18" -102.5dB *
    MK MX-125 101.8 - dB / 25hz - no SPL given
    TRIAD Silver - 100.2dB / 25hz - no SPL given
    PBS Subsonic III - 100.1dB / 25hz - no SPL given
    SUNFIRE <100dB
    MK V75 MarkII -98.1dB
    Allison NL-5400P -96.4dB / 25hz -no SPL given
    Altec Lansing PSW10 -95.5dB /32hz - no SPL given
    KEF 30B AV - 93.5 dB ~(32-50hz) / 32hz - no SPL given
    ---the following use a 31hz to 63hz range.---
    Boston Acoustics cr400 - 99dB / 25hz - no SPL given
    Paradigm PS-1200 -98dB / 25hz~91.4dB **
    Phase Technology power10 -98dB / 25hz-no SPL given
    Acoustic Research S12ho - 97dB / 32hz-no SPL given
    Mirage PS-12 - 96dB / 32hz -no SPL given
    Sound Dynamics RTS-800 - 95dB / 32hz~92dB
    MK vx-7 - 89dB / 32hz-no SPL given
    Audiosource SW eleven - 88dB / 32hz~78dB
    ---the following use a 31hz to 80hz range.---
    POLK psw150 - 105.4dB
    MB Quart D1200si - 104dB
    NHT sw 1p - 101.9dB
    BOSE am15 bass module - 100dB / 32hz ~97dB
    INFINITY BU120 - 100dB / 32hz~90dB
    MIRAGE PS-8 - 99dB / 32hz~90.7dB
    Sound Dynamics rts800 - 98dB
    PSB Subsonic 1 - 97dB
    Paradigm LEGEND tower(10"-100w built-in sub) -93.1dB
    NOUSAINE's IB design - (12-63hz) - 120dB
    The four DIY setups NOUSAINE reviewed in the
    JAN-1999 AUDIO...(all 25-63hz)
    RK(4-18s) - 126dB
    TH(4-15s) - 116dB
    RP(2-18s) - 107dB
    TP(8-12s) - 123dB
    TV
    Paul
    Paul
    • 16478
    Wow very impressive..I wonder what a single would have done?
    • P-Dub
      Office Moderator
      • 6766
      I made an edit to the original post to Bold and add 'SVS' to the single SVS reading.
      Paul
      Paul
        • 16478
        thanks paul I read the thread over on HTF..seems like the SV boys know what they are doing
        • John Holmes
          • 2707
          That's my baby! :B
          • GregoriusM
            • Oct 2000
            • 2755
            And to think that the reviewer was reviewing one of their very first products is amazing. They seem like a couple of pretty cool, hard working guys over at SVS.
            Gregor
            • Trevor Schell
              • 10936
              Very impressive!,,
              The upgraded Samson 700 watt amp is supposed to provide even better performance than the 600 watt Fidek.:E
              Trevor
              My HomeTheater S.E.
              Sonically Enhanced
              C5
              Trevor
              XBOX 360 CARD
