Help Please Easy Question (for you)
  • spyboy
    • 118
    I have 2 different kinds of speaker wire with different markings for polarity. How do I know when I run the differently marked wires from my power amp to my speakers that they are in-phase?
    Thanks in Advance
  • dyazdani
    • 7032
    It doesn't matter what the markings are as long as the (+) on the amp goes to the (+) on the speaker for each channel. I'm assuming your 2 sets of wires are one for the left and one for the right?
    Danish
    • spyboy
      • 118
      Yes, the 2 lengths of wire are for left and right. They have different types of ridges to indicate polarity. So, are you saying that as long as I use the side of the wire with the raised ridges as the Positive on the amp and the speakers, they will be in-phase?
      • dyazdani
        • 7032
        Yes, as long as the wire with the ridges connects the same polarity on the amp and the speaker, you will be fine.
        Danish
        • dyazdani
          • 7032
          BTW, you can usually tell when the speakers are out of phase as your imaging will be messed up. i.e. no defined center image, etc.
          Danish
          • theMaximus
            • 179
            That is correct. Most wires have markings on the positive (+) side. As long as positive sides both wires go to the positive posts of the speakers, you will be fine.
            It is genereally recommended that you use the same speaker wires for both sides and similar in length regardless of the distance between the speakers and the amp. For example, even if one speaker is a lot closer to the amp than the other, use the same length cables for both speakers. This is just a rule of thumb.
            Victory Shall Be Mine!!! :heh:
            • dyazdani
              • 7032
              Yes, ideally you'd use identical cables - identical in both type (brand, model, etc) and length.
              I have seen (and done myself) double bi-wire configurations with different types of cable for HF vs. LF posts. Not to cofuse this issue though...
              Danish
              • renton
                Do individual crossover components have polarity?
                by renton
                Hello all,
                I am starting to piece together the crossovers for my NatP build and it struck me, do the individual crossover components have polarity? I could not see markings on anything, so does it matter which end of a cap hooks to say, another cap? If their is a polarity, how do you...
                11 June 2007, 21:10 Monday
              • efarstad
                How to check your polarity!
                by efarstad
                When I wired my HT I made sure that I always used the side of the wire with the writing on it to the negative terminal. Well I recently switched out speakers and realized one of my back surrounds...doh...I couldn't read teh writing and I forgot which one was positive and negative. I played music with...
                27 May 2003, 11:18 Tuesday
              • jacket_fan
                Newbie question on driver polarity
                by jacket_fan
                I am working on my first speaker project. I did a search, but did not find an answer to a real basic question. So forgive my newbie dumb question. But you gotta start somewhere.
                When I hook up the drivers to the crossover, how do I know I have the polarity correct? I got a kit from...
                03 January 2011, 08:06 Monday
              • beden1
                Classe Amps - Possible Case for Speaker Wires
                by beden1
                Possible case that speaker wires and balanced versus RCA connections make a difference that I had not considered.
                This hobby is complex in nature, and it's interesting that one gets to continue learning along the way through experimentation.
                Case in point: I have owned...
                20 October 2008, 12:24 Monday
              • John22614
                Bare speaker wire connections
                by John22614
                Curious how many of you use bare speaker wire connections and how you deal with wire corrosion. I just replaced my speaker wires using 10 gage 8 foot runs with bare connections to both my amp and speakers and it sounds really good. How often do you think I need to cut back the wire to deal with corrosion?...
                20 April 2010, 09:37 Tuesday
