How to check your polarity!
  • efarstad
    • Jun 2001
    • 2230
    When I wired my HT I made sure that I always used the side of the wire with the writing on it to the negative terminal. Well I recently switched out speakers and realized one of my back surrounds...doh...I couldn't read teh writing and I forgot which one was positive and negative. I played music with it connected both ways and still couldn't tell. :? :loser:
    Well I just was told this little trick. Grab a nine volt battery and at your amp/receiver end connect one wire to the positive and then touch the other wire to the negative end on the batter and if you see the speaker drivers pop "up" a little then your speaker in "in phase" if they "suck in or down" then your speaker is out of phase and you need to switch your wires!
    I thought that was the coolest trick...and thought I'd pass it along!
    E
    The Norwegian A/V Nut!
    E-Cinema
    E-Cinema
    • 27460
    Nice trick E!
    Lex
    • Kevin P
      • 10812
      I've used the 9 volt battery trick to test speaker wiring or to figure out which speaker the wire went to (for connecting to the appropriate channel on the receiver/amp) but I never thought of using it to check phase. Of course if the speakers have non-removable grills that won't work.
      I always use the phase tests on the AVIA DVD to verify phase (polarity).
      KJP
      My HT Site
      • efarstad
        • Jun 2001
        • 2230
        Kev: You can still check with non-removal grills! Just push down on the grill a bit and then feel for the driver to push up against your hand...vwella! If you don't feel anything then it's probably pulling in instead of out...of course you'll need two people if your equipment/speakers are not in eyesight or too far away like me or in a different room like me! 8O
        E
        E-Cinema
        E-Cinema
          Or, you can do a variation of the 9-Volt battery trick. Connect the positive terminal to your positive speaker wire, and negative to negative. Then when you're at the speaker making the hook-up, just lick both wires simultaneously. This will provide you with positive feedback to remember to go back and check which wire was which at the source. Checks continuity too. I recommend it to all the HT newbies.
          Oh, and I always do all polarity, channel, etc tests from Avia and Digital Essentials.
          Luke: "Hey, I'm not such a bad pilot myself, you know"
          • Bruce
            • 156
            I'm just check'n in on this and maybe it's a stupid question, but what if your 2 or 3-way speakers have the individual drivers connected out-of-phase with each other (many more are like this than you know). Mine aren't but that's because I have 2-ways with first order crossovers.
            How do you know when a cone moves out which one is correcty in-phase if all the drivers aren't in-phase with each other? Is it mid-range driver cone, tweeter cone, or woofer cone that you go by? I probably couldn't tell what the tweeter dome was doing anyway.
            Bruce
            ____________________________________________
            Bruce
            • Kevin P
              • 10812
              You'd go by the woofer cone. Hopefully your crossover isn't allowing DC to go through the tweeters!
              My HT Site
              • Clive
                Home Theater Glossary
                by Clive
                G'day Members. As part of our efforts to assist new and seasoned members I am starting this thread, to be used as a quick reference guide.
                I am sure that there will be some missing from this original list so in that case I will ask that members can post the words and there meaning/explanations...
                11 July 2005, 22:38 Monday
                Integrating a phase reversing pre into a HT system
                by Briz vegas
                Hi guys
                Rel subs have a high level connection via the left + & - and the right + only at the speaker connections on the power amp. They also allow you to have this high level connection and a low level connection hooked up at the same time.
                How do I do a high level...
                08 October 2006, 06:11 Sunday
              • Victor
                Driver polarity in a Dipole Woofer
                by Victor
                …I have not posted anything in quite sometime, - been busy finishing up my Home Theater…Oh, well, - it seems it is a never ending story…
                Some perhaps remember that I built a rather large dipole 3-way speaker system; here is what it looks like.
                It...
                06 November 2004, 16:19 Saturday
              • JvdL
                Statements II Polarity Question
                by JvdL
                Hi guys!
                This is my first post here, but I've been reading a lot on this forum, I saw a lot of topics on the Statements build by Jim & Curt.
                I finished my statements II about a month ago. Most of the time I really like the sound, but sometimes it's not what I expect it to be....
                09 November 2015, 11:50 Monday
              • Glenee
                Jumping the Negative post on the 802D in Bi-Wiring
                by Glenee
                I am going to Bi-Wire my 802D's. Some say it makes no difference( single wire or Bi-Wire) But a lot of people have mentioned that if I do Bi-Wire to be sure and jump the negative posts. What do you guys think?
                Glenee
                11 December 2006, 22:16 Monday
