Richard Grey Isogrey System
  • Nolan B
    • 1792
    Does anyone currently have a Richard Grey Isogrey System including a RGPS 600s/1200s and Pole Pig? I have the RGPS 600s and am planning to ad a Pole Pig. Its recomended to put all of your "front end equipment" into the Pole Pig and "back end equipment" into the RGPS 600s.
    My question is what is considered back end and front end. At this point i know that DVD players are front and amps are back end. What are plasmas considered?
    Put display devices with front end gear.
    • Nolan B
      • 1792
      thanks. So really the only things that are back end are amps?
      • Nolan B
        Richard Grey 600s
        by Nolan B
        I current own a 600s and noticed on the back there is something call a "20 amp IEC connector" and a swtich for "fast and slow".
        Tomorrow and electrician is comming to install a deditacted 20 amp circuit for my HT. Do I need to do something with this swtch? can someone...
        01 November 2006, 20:21 Wednesday
      • BlazeMaster
        Should I keep 600s/exchange for 602s?
        by BlazeMaster
        Hi, everyone I just got my 600s almost 2 weeks ago, and am thinking about exchanging the 600s for 602s. I can then put the 602s in front to match the LCR600 better and keep my 601s that I have as fronts right now and then use them for surrounds. The price difference would only be about $300. The...
        08 November 2004, 01:13 Monday
      • Timbo
        Di-Pole bass & MTM
        by Timbo
        I have been reading all of the comments that di-pole woofers can provide the most natural bass in the room with the least amount of room reasonance. Is it possible to intergrate a "H" baffle woofer system with dual 10" or 12" and use it as a stand for a sealed MTM monitors like...
        09 December 2006, 16:37 Saturday
      • Drewbert
        Are the 600s that bad?
        by Drewbert
        I know some of you ball out of control and have 800s.... I dont have that much extra cash to toss on some freakin speakers...
        So how are the 600s.... used they dont seem to be that bad at all... I can justify spending that much. Plus I like the way they look with the covers off..
        How...
        22 August 2005, 21:10 Monday
      • brianpowers27
        Please help me to understand the transfer function of a bi-pole. (not dipole)
        by brianpowers27
        In the past I have used the baffle simulator in Jeff B's Response Modeler 2.1 to visualize the transfer function of a dipole based on the the total path length (x dimension) from driver to driver.
        I imagine...
        13 July 2009, 10:33 Monday
