Audiophile Breaker box?
  • musman
    • 57
    Our hobby is out of control.
    • 1930
    Rather make one myself. Not hard at all.
    • brac
      • Aug 2005
      • 90
      Something not right about the story I guess since canada only allows 15a breakers there are no electric stoves, water heaters, of appliance........
      Go Figure....
        • 16877
        Wow, sounds good! I have no idea about the authenticity, engineering details, etc, but sounds like a good premise.
        • NonSense
          • Nov 2003
          • 138
          Go Figure....
          You won't find any reputable electrician who would install a non certified piece of equipment. Liability is too great.
          The problem here is the rating of this breaker if it were to be wired to existing house wiring and receptacle. Most existing residential wiring is #14 AWG. If you are talking 32A breaker with a run of over 45 feet you need to use #8 AWG wire. Most receptacles will only accept up to 12 AWG wire size with a few being able to accept 10AWG (Rare). Conventional receptacles are rated at 15 (and 20 Amp, horizontal slot) unless you move to more exotic twist lock types.
          It's not the breaker size that is the problem, but more likely that this person was interested in a wiring scheme that was against the electrical code.
          Bruce
          • whoaru99
            • 638
            Pimp my ride...
            I suppose if your system is in need of that last 0.000001%, I guess this would be the way to go.
            ----JAFFE'S PRECEPT
