Well, the little guy has learn that the stereo has cool little lights, and now makes a run for it when I walk away from the room. Since he now knows right and wrong, he is learning to leave it alone, but my Parasound amp is at the bottom of the audio rack, and right now it gets too hot to touch. So right now, I have to be proactive and make sure it doesn't burn him. I have decided to place the tinted glass door back on the audio rack to keep him out, but I need a way of cooling the amp. The back is completely open, but I still need a good airflow. I purchased a 120mm fan this weekend, attached it under the shelf that is directly above the amp, and control the fan with a fan controller from my HTPC that is sitting on the shelf above. However, I have two issues with it. One, the fan is too loud. My HTPC is almot dead silent, but the cooling system is very effective, never even warm. The fan is suppose to be a quiet one, but at full load, it's that buzzing annoying sound. I can lower the voltage on the fan to slow it down, but it's pretty much pointless at that speed since with the door close, the amp gets way too hot. I was watching a movie last night, close the rack door, had the fan on full power, and the amp still got way too hot with no airflow.
What have you guys done with closed audio racks in regards to cooling? The wife suggested placing the amp on top of the rack and give it open cooling, but that amp is heavy. I'm a little concern with how well that rack with do with that much weight on top.
