speaker terminology
  • i_amadeo
    • 110
    speaker terminology
    hi all i am going to spend about ...well lets say alot.... on speakers and i realy would love to understand what makes my future speakers shine from the rest so i have been researching and studying the speaker specifications .....only to find out how hopless my case was ...i barely understood any thing on the paper
    i would realy like to know what is
    sensitivity ......and is ....(2.83v/1m): 90 db ....good?
    frequency responce ....and my speakers state a 38 hz -30 khz what does that meen( and also ....on axis and off axis )
    crossover frequency ....again 400hz /3khz
    low frequncy extension ?
    if its not so much trouble ...thanks
    come into the light
  • Stoney
    • 232
    Here are some basic definitions.
    2.83v/1m 90db: is how loud (sound pressure level=spl) the speakers are, measured at 1 meter with 2.83v input. This measurement is usefull to determine how much amplifier power you will need to produce a certain listening level. Compare with other speakers you may know or be demonstrating.
    On Axis would be directly in front of the speaker. Off axis measurements, eiither horizontally or vertically would indicate how far from offcenter (right to left or up and down) you could move without effecting what you hear.
    Frequency Response; Humans are theoretically capable of hearing frequencies from 20 to 20,000 Cycles Per Second (Hz). A perfect speaker would be able to reproduce all frequencies in the audible range at the same volume with no distortion. It is also desireable to have frequencies in the sub audio range (very low frequencies 10-20 Hz) for movie sound effects and bass sounds.
    Crossover Frequencies; These are the points that the speaker will divide the frequencies to the separate drivers. In your example, below 400 Hz go to the Low frequency speakers (woofer), from 400-3,000 Hz go to the mid range, above 3,000 Hz go to the High frequency speakers (tweeter).
    Low frequency extension: not sure what is meant. Would probably need to see it in context.
    Specifications give you general guidelines for comparing speakers on paper. Most important is that you actually listen to them and compare what you hear. It would be best to have them in the actual environment you will be using them in (room acoustics can play a big part in how they will sound) and drive them with the equipment you will be using.
    Hope this is helpfull. If any one can explain further, please do so.
    some links (please note that these are simply some info pages I found. I do not particularly endorse any of the products that may be sold on these sights)
    http://www.thespeakerstore.com/glossary/tech.htm
    Emotiva UPA-700 Amp
    Emotiva UMC 200 pre/pro
    B&W DM605 S2 Mains
    DM602 S2 Surrounds
    DM601 S2 Rear Surrounds
    CC6 S2 Center.
    ASW 1000 Sub
    • i_amadeo
      • 110
      thanks man for your help my next question is if i want to biamp my speakers i only have one rotel power amplifier how can i do that ,,,,there are 4 speaker reds and balack on each speaker and only 2 on the amp
      come into the light
      • Shane Martin
        • 2852
        First you'll need to remove the gold jumpers off the binding posts, then you will connect a set of wires to each post from your amps(2 from each). To connect the amp to your preamp/recever/processor you'll have to use a y-adapter to split the signal from the pre to your amps.
        To answer your question: This is about average. This is really borderline going into lower efficiency. As a rule to add 3 db you need to double your amp power so to produce 93db at 1 watt you'll need 2 watts instead of 1 meanwhile a speaker like Klipsch only needs 1 to produce 93db.
        • fjhuerta
          Power response, acoustics and how a "flat on axis" design sounds in a room
          by fjhuerta
          Hi all,
          I've been playing around with one of my designs (the Monoliths): a 2.5 way with Peerless 830884 drivers and a SEAS 27TBFC on top. My parents have them, and they asked for a bit more top end sparkle (I assume due to their hearing loss).
          Anyway, after further refining...
          15 February 2009, 18:29 Sunday
        • ray5
          crossover frequency
          by ray5
          Crossover frequency
          Hi!
          Just wondering about the crossover frequency to the sub. I have read the various threads on this but my installer did a curious thing. He has set the crossover...
          13 October 2009, 08:37 Tuesday
        • bcodemz
          The ultimate small speaker - final design critique/improvement
          by bcodemz
          Hi everyone. I'd like to get some feedback for a design that has been in the making for a year or so now. The goal is to design the very finest small speaker with the challenge to pack as much performance into a speaker that physically looks small, which I determined to be a wide but short speaker like...
          25 August 2016, 21:41 Thursday
        • wowo101
          The Endeavour, a 3.5 way active speaker concept
          by wowo101
          After a few stabs at dipoles in the last two years, I've recently worked on an active speaker concept I call Endeavour – and it really is, since I'm still very much a beginner (although I've learned a lot in theory from you all). By now, it's concept only, and before going any further, I'd like to...
          02 August 2012, 17:33 Thursday
          Driver bandwidth and determining crossover frequency: Questions
          by dlneubec
          According to Dickason, the general rule of thumb (of course there are exceptions) for the lower crossover limit for midrange and tweeters is to be at least 2x the FS of the driver, 3-4x is even better.
          He also suggests that the upper level crossover for woofers and midranges should be...
          12 March 2007, 13:59 Monday
