Hi all,
I've been playing around with one of my designs (the Monoliths): a 2.5 way with Peerless 830884 drivers and a SEAS 27TBFC on top. My parents have them, and they asked for a bit more top end sparkle (I assume due to their hearing loss).
Anyway, after further refining the design, I took a measurement at 1.8 meters, and it was dead flat on axis. Off axis (starting at 15°) a small "flare" centered at around 4 KHz was visible (no big deal, I thought).
But, when I took in-room measurements, the small flare was now a +4 dB hump, centered at that same frequency. The speaker was pretty good except for that.
Now, the room I'm using the speakers in is far from optimal. Hardwood floors, concrete walls covered with hardwood, tile floors around, bare walls, etc.
I did an experiment. I took even more in room measurements with an RTA. At 1.5 meters, on axis, the speakers were flat (except for some floor bounce, which cancelled some of the bass). As I kept walking backwards, the 4 KHz bump became more and more evident. Then I took the 1.5 meters on axis measurement, and noticed that walking to the center of the room, at that same distance, also showed the flare.
Here are some questions I need some help with. Some are dumb, some are really dumb, and some are puzzling.
1) Is the 4 KHz bump to be expected? Is it a function of the room?
2) How do off-axis flares reflect on an RTA in room? Would I still see the flares, even if the room was properly treated?
3) If the speakers are facing forwards, and I'm sitting in the center of a triangle between them, am I listening on-axis, or off axis? (Please don't laugh, I started thinking about this and I don't know. I'd suppose I'm off-axis, but I'm not sure).
4) Since my wife will never let me treat the room, would a bit of EQ help things?
Thanks a lot for your help!
