Question: Moving Audio source to another room
  • phatpauly
    • 3
    Hi folks...newby here.
    I want to move my source for my multi-room audio to another room. Is there an easy way to take the speaker wire and route it back into the inplace structured wiring (CAT or RG6) so that I can put the source in another room with a minimum of hassle? Thanks!!!
    I truly appreciate any help you can offer.
  • phatpauly
    speaker wire to rg6?
    by phatpauly
    I want to move my source for my multi-room audio to another room. Is there an easy way to take the speaker wire and route it back into the inplace structured wiring (CAT or RG6) so that I can puty the source in another room with a minimum of hassle? Thanks!!!
    19 February 2005, 01:16 Saturday
  • menancyandsam
    Is this too much receiver for my speakers?
    by menancyandsam
    I own JBL LX-44 speakers (rated to 150w), plus the usual aray of mid-priced surround speakers. I'm looking to buy a receiver for HT use (30%) & music only use (70%)-(by the way I like listening to Classical & to rock music & my room size is 14x30). I would also like to listen to seperate...
    08 December 2004, 17:22 Wednesday
  • menancyandsam
    by menancyandsam
    08 December 2004, 18:17 Wednesday
  • cmr15
    Another question about 1056 redirect
    by cmr15
    I know that this issue has been addressed in the forum, and I have done a search to investigate it myself. However, I'm a bit confused and would really appreciate your answers.
    I am probably going to get the 1056 and add and amp like the 1070 to power my main speakers for good 2 channel...
    30 June 2004, 07:45 Wednesday
  • audiofiyle
    Will Rotel build another 1090??
    by audiofiyle
    Hi everyone, this is my first post to Htguide Rotel forum. I currently am running 2 Rotel amps in my system right now. The 1080 driving my Dynaudio
    focus 220's, and a 1075 driving my center and surrounds, and a pair of Niles
    out on my deck. Here's the deal, I want to setup a second 2 channel...
    11 January 2009, 14:03 Sunday
