Experimenting with an inexpensive wireless DAC transmitter from NAD
  • Ovation
    • 2204
    Just got (99$ CDN) a NAD Wireless DAC 2. Very basic addition to my otherwise totally wired setup in a reading room (vintage Yamaha C-45 pre-amp, a universal audio disc player, even a MiniDisc home deck :E , Emotiva 2 channel amp) to stream newly lossless Apple Music service from my work space nearby. Hope to get it all up and running soon. Certainly nothing cutting edge, but will greatly expand my music library in that spot.
    • 1577
    Interesting little device! What sort of distance are you looking at operating this?
    Not quite that inexpensive in the states though, I'm seeing it for $250 here.
    • Ovation
      • 2204
      Hmm. It retailed at 199$CDN when new in 2016, but now is usually listed for the 99$ I paid for it (was the main reason I got it). I've got line of sight between the two pieces at about 5-6 feet max, so I fully expect it to work seamlessly from the wireless transmission point of view. Apple Music just went lossless about a month and a half ago, so this will allow me to stream from my laptop or iPad at a minimum of 16/44.1 all the way to 24/96 (some Apple lossless music is listed at 24/192, but I'm not that fussy for this particular setup). Again, not cutting edge, but certainly convenient.
      • mb225
        Apple AirTunes sound Quality
        by mb225
        Does anyone have experience with Apple AirTunes? I’m referring to the ability to stream music from iTunes to an AirPort Express or the new Apple TV. Both use 802.11n for wireless connectivity. I’m currently using a MacMini as a music server and I was thinking of adding an AirPort Express to be...
        09 December 2010, 15:05 Thursday
      • Gianluca
        Wireless Audio/Video
        by Gianluca
        Hi guys,
        I purchased an audio/video sender, so that I can get a kitchen tv up and running. I purchased a 1.2GHz 12 Channels 100mW Wireless Receiver & Transmitter Kit.
        I could of purchased more powerfull ones but I am worried about it being harmful. Should I be worried?...
        12 December 2010, 19:17 Sunday
      • Stevebez
        RSP-1068, decoding Apple Lossless?
        by Stevebez
        Hi there .... Been away for ages, and now have all my CD's on a NAS (compressed to Apple lossless) and wondering if I stream the lossless files to the RSP will it decode it? Also, I have not figured how to send it the data yet .....
        Saves me form getting another DAC set...
        28 February 2012, 18:01 Tuesday
      • Pookie007
        KEF Wireless System
        by Pookie007
        Has anyone used the Kef wireless system for their rear speakers. the system consists of a transmitter and two receivers that operate in the 2.4GHz range. I think the suggested retail is around $600. I play audio in 2 channel, so this would only be used for HT applications. I think the $600 might...
        28 November 2007, 00:12 Wednesday
      • SteveA
        wma vs wma lossless
        by SteveA
        I have a question or two about wma vs wma lossless encoding. I just set up a new PC. I have a wireless router to use, primarily, for the Squeezebox I just bought.
        I ripped a CD just to go thru the process (bit of a newbie here) and noticed that the file extension was .wma. Playing...
        13 April 2005, 14:29 Wednesday
