Suggestions for 2.1 desktop system?
  • Supernova
    • Mar 2017
    • 108
    I wanted to put together a desktop system with a DAC and amplifier or intergrated amp and DAC that would power 8 ohm speakers and has between 80 and 100 watts. I'd also like the unit to be able to run my headphones. My budget is around $1000. I found plenty of DACs in the mid $500 range (schiit, emotiva etc), but haven't found a good amp that would put the entire package in the $1000 range. I'm looking for something compact, so none of the full size components. The only thing I found that comes close is Wyred4Sounds mINT integrated amplifier and that comes in at $1500, which is doable, but wanted to see if there were other options?
    Oh and I have a power sub for the room.
    maybe this NAD?
    D3020
    • Supernova
      • Mar 2017
      • 108
      maybe this NAD?
      D3020
      That's a nice unit. A little less power than I was looking for. This will be used to drive some Concentric 8's and in a large office with a sofa in the back. While I don't always listen at high volume there are times when I finish a mix or track and like to listen at louder levels in the back. I guess I'm just trying to see what'a available. I've seen a lot of brands on this site I had never heard of before.
      • DDF
        • Dec 2007
        • 11
        nuprime ida8, but doesnt have headphone out. Loving mine on the desktop, 2.1. Detailed, great sence of space, very easy to listen to
        Sent from my SM-P600 using Tapatalk
          • 4157
          The NAD seems to be above the power floor for those speakers, and the NAD should provide sufficient current to drive them, depending on their sensitivity of course.
            • 16166
            And like other NAD's, it's designed to provide higher peak power for transients, above the continuous power rating.
            • Supernova
              • Mar 2017
              • 108
              That's a very good find. I'm not familiar with nuPrime, but they have a couple amps that could be used in a combo like the NUPRIME AUDIO STA-6 with the emotiva DAC or Schiit DAC. The benefit with a combo is I gain a headphone amplifier and can upgrade the other components in the future (probably wont).
              93dB - 2.83V/1m sensitivity. I tend to prefer having extra overhead when driving a speakers (could be something wrong with my internal wiring), but it may not make a difference.
              I see a lot of people here really like the NAD. I just moved to NZ from Colorado Springs and gave up 2 NAD 2400's because they would require a step down converter. They were very old amps and pretty average, but they were acquired from my parents estate, so I can't complain. My only reserve with NAD is that I bought a CD player from them in college, more than 25 years ago, and it never worked properly. I sent it in several times for service and they sent it back, but it still didn't work. It would play for a few minutes and then just stop and it didn't matter what CD I used the same problem happened every time. The second time they sent it back it had white goo on the power cord and housing. After the second time they refused to service it any further. It never worked properly and always left me feeling screwed. It was a big purchase for me at the time and I had no recourse. I know it was a long long time ago and just a CD transport, but it's gives me reservation. I'm sure in that time management and quality of products has changed.
              Anyone else familiar with NuPrime? Any reservations about using something like the STA-6 with a Schiity DAC or the DC-1? Will the NAD be a better unit or does it even matter at this price point?
              I appreciate the help.
              • DDF
                • Dec 2007
                • 11
                I thought about the same amps you are but to me this seemed to have a better rep for sound quality. I bought it sight unseen on a risk, but have no regrets. I design my own audio gear for many years so no buyers blindness (and I think a pretty keen ear), and the unit ain't perfect, but its trade offs are perfect for what I wanted in an office system.
                The unit is small, looks great, plays loud enough. It doesn't have the current reserves of a NAD (different design architecture). If your speakers are low impedance, NAD will give you more voltage for the same "8 ohm" power rating. But if you're speakers are 93 db sensitive, this will still crush.
                My experience with NAD is that it had a dynamic, almost punch sound, in this price range. Don't know if the D3020 or others of that ilk do as well. The Nuprime doesn't have that sort of sound. I level matched it (<0.1 dB) against the Bryston it replaced and the Bryston sounded subjectively louder as it was a punchy amp. The Nuprime will kick if turned up, but at lower levels, its less obtrusive and has no hype, but great detail, and awesome imaging. Perfect for what I wanted in an office system where it's not distracting, still sounds fantastic. I listen to music allot more now while I work. It also has a dedicated "sub out" but with no filters, works as intended. Remote is good but needs line of site. Only 1 analog i/p but probably more than enough for most
                Nuprime IIRC correctly are the same guys as the old Nuforce, been around a long time.
                Not sure how critical your HD listening will be, but what I do is use the Nuprime for 2.1 speakers and a separate HRT microstreamer for HD.
                With the favourable US exchange rate, you might get a good deal at:
                NuPrime is a company committed to design, engineering, and excellence. It’s made up of talented engineers who are passionate about what they do. In 2015, NuPrime received four prestigious Product Of The Year awards and was recognized in two high-end audio magazines. Over the years, NuPrime has been honored by more and
                No affiliation with the store, but bought mine there and had it in my hands a week later, no muss, no fuss.
                  • 4157
                  Nuforce made some nice stuff. Some early makers of actually decent sounding Class D amps when that wasn't so easy to find.
                  • Supernova
                    • Mar 2017
                    • 108
                    Thanks guys for the help. Tough choice to make. I see benefits of both the NAD and NuPrime. That Canadian price is good, I wonder if they ship to New Zealand. I'll have to check the price to that of an Australian distributor, but those bloody Aussie's usually gouge us New Zealanders. I usually find it cheaper to buy in the US and ship it over and I haven't been here long.
                    • Supernova
                      • Mar 2017
                      • 108
                      I inquired and they do not ship outside of Canada, but certainly good prices.
                        DAC in the Box?
                        Andrew Pratt and I recently exchanged some mails on the topic of universal SACD/DVD players, and other alternatives for Redbook CD playback. One of the topics which subsequently came up was ~$1000 class DAC's, and what might get you into genuinely high end sound. I think Andrew was a little surprised,...
                        07 August 2003, 21:29 Thursday
                      • Armbender
                        External DAC with SSP-600
                        by Armbender
                        Wondering which DAC`s if any would be an upgrade over the DAC in my SSP-600. I am running an AppleTV toslink into my SSP600 right now. Just thinking that adding a DAC that offers Balanced out will let me take advantage of the SSP600`s advantage over the 300.
                        Looking at the $1000 range...
                        12 August 2010, 12:03 Thursday
                      • Kibble Fat
                        First-timer with special desktop needs
                        by Kibble Fat
                        Hello everyone!
                        For the last couple weeks I've been closely researching about a dozen MT and MTM speaker designs for 85% music, 15% games and I need help narrowing down my choices. I just finished an AMB Gamma-2 DAC to be fed by my laptop so I'm ready to replace my current desktop rig....
                        23 August 2010, 22:36 Monday
                        Oppo BDP-95 or BDP-93 + External DAC
                        by audioqueso
                        I have $1000 for my new audio toy.
                        Time to upgrade the source. Looking for recommendations
                        Short Background.
                        I recently brought out my Technics turntable. Added a Audio-Technica 150MLX cartridge, rewired the inners, and bought a Cambridge Audio 640P. The results were...
                        18 August 2011, 20:35 Thursday
                      • mskvarenina
                        My Theta Digital Pro Basic III died
                        by mskvarenina
                        This wasa great DAC and served me for many years. Unfortunately it no longer will sync with my digital sources and I'm told Theta Digital cannot service it.
                        Please recommend an equivalent or what you feel is the best alternative DAC below $1000. The DAC in my AVR-4311 just doesn't cut...
                        29 December 2011, 00:33 Thursday
