Which will sound better: Sound Card+7.1 Speaker VS Nvidia Card+Home Theater
  • richerrich
    • May 2014
    • 3
    Which do you think will sound better: Soundblaster Card+7.1Creative Speakers (via Stereo Cable) VS Nvidia Card+Home Theater (via HDMI)
    Thank you.
    • 16125
    There's not really enough information the way you've presented your question- I'd normally expect it to come down to jitter, quality of the converters, and amplifiers and speakers- if the latter configuration is transmitting the audio by HDMI to a home theater setup and it's DAC (? receiver? what speakers?) I'd usually expect that might be the better choice for a variety of reasons- none really related to the digital audio stream per se. But without real facts or specs to work with, there isn't enough info to offer an informed opinion.
    • richerrich
      • May 2014
      • 3
      Hi Jon Marsh,
      Sorry if my post hadn't provided enough specs. I did post more details in Home Theater but I got no response for some time so I thought maybe I should just mention things in general, hoping others have similar specs.
      I would have mentioned: SoundBlaster Audigy 2 Value Sound Card + 7.1 Creative Inspire T7900 Speaker (via Stereo Cable)
      compared to
      Nvidia GTX660 + Onkyo HTS5600 Home Theater (via HDMI)
        • 16125
        What's your goal with the audio? Gaming? Video? Music? (what kind...?) The Creative speakers are not exactly high end- neither is the Onkyo, but it will do multi-channel- is that important to you? If so, that's likely the way to go.
