best DVD audio outputs???
  • asg420
    • 21
    Hello again,
    I have what some of you will consider probably a pretty basic question.....but your explination will be greatly appreciated!
    What is the benefit of using 6 channel audio outputs from your DVD player? Is it better to use an optical or coax output into the processor?
    I currently have a Denon 3800 DVD player - I may want to upgrade this piece as well but want to first try to get the best sound possible from this player for now.
    Thanks again!
    asg
    Twin Moderator Emeritus
    • 16706
    For Dolby Digital / DTS stick to the digital outputs. You have to use the 5.1 analog outputs to hear any of the high resolution tracks on DVD-A / SACD unless your player/prepro has some sort of firewire or otherwise "secure" digital connection.
    • theMaximus
      • 179
      Use the 6 channel output for DVD-Audio and digital output (digital coax or optical) for movies. In order to listen to DVD-Audio, you have to use 6 regular RCA cables for 6 channel output. I would recommend connecting your DVD player with both connections and switch between multi-channel audio (DVD-Audio) and digital audio (DVD movies) with separate input in your receiver. Remember that both your receiver and DVD player have to support 6 channel audio in order to listen to DVD-Audio. Check the back of your equipment or owner's manual to make sure. I hope this information helps.
      Victory Shall Be Mine!!! :heh:
      • asg420
        • 21
        Thank you both!!!
        Thanks guys -
        Some VERY helpful inforamtion - I get it now....
        One other question....Does the analog output from the DVD player provided un coded sound to the processor? Does the Processor do the decoding of DVD-audio or is the sound processed by the DVD player and trasnmitted via the analog ports in 5.1 channel decoding.
        Cool stuff!
        Thanks!
        asg
          • 16706
          Processed in player and output as analog
          • asg420
            • 21
            Thanks!
            :t
            Thank you!!! Good to know these things....
            I love the cleanest, clearist, full bodied sound I can find.....I am now finally taking the time to learn how it actually all works! :B
            asg
              New DPS 5.4 DVD Player announced
              Guys-
              I don't usually lurk in this forum, but I received an E-mail today from a friend in the industry passing on this press release. thought you might like to take a look:
              Luke: "Hey, I'm not such a bad pilot...
              24 July 2003, 02:59 Thursday
            • ntt
              good DVD player with YCbCr out
              by ntt
              Hi guys,
              I need an advice on getting a new DVD player.
              I currently have a projector and connect to it using a 50ft component cable. I was puzzled for a long time by the fact that DVD picture from my Playstation2 is visibly better than that from my Samsung HD841. A friend...
              15 April 2005, 12:36 Friday
              Interesting new DivX compatible DVI DVD player
              This player is being brought in from the folks who import the Momitsu, but it's not a Momitsu.... and it has Faroudja DCDi de-interlacing. The lack of the Faroudja processor in many upscaling DVD players is a sore point, IMO.
              OPDV-971H DVI/MPEG/DIVX/XviD DVD player
              10 December 2004, 18:07 Friday
            • zztopp
              DVD player upgrade
              by zztopp
              Hello guys this is my frist post. Iam an the process of upgrading mydvd player which is a toshiba sd5700 the toshiba is ok for video but not dvdaudio. I have auditioned the rotel 1060 and denon2900 the rotel out performed denon hands down. But before i buy the rotel can you recomned another dvd player...
              25 February 2004, 01:10 Wednesday
            • spiffnme
              Rotel DVD player?
              by spiffnme
              That last two pieces of my HT is a new TV and a new DVD player. I've been researching DVD players a bit, and I've got a few ideas I'd like to throw at you.
              I'm a cheap bum, but want the best possible CD audio playback, AND the best possible video quality. Bang-for-the-buck drives ALL...
              14 October 2003, 22:28 Tuesday
