5.1 sound from Sat TV?
  • Charl
    • Apr 2004
    • 50
    I run my digital satellite tv signal through my new NAD T163 pre/pro but can't get decent 5.1 sound from the surrounds and sub. The satellite box has a digital out, which I connected to a digital input on the pre/pro via a high quality digital coax.To test the sound effects I set the main speaker levels all the way down and the surrounds all the way up, but I only get 'warbled' and incohesive sounds from the surrounds and the sub. This happens in all decoding modes (DPL, DPLII, etc.) and with all programs (MTV, etc.), although the front always sound fine. DVD's work great, also via digital coax.
    Surely this can't be right or am I being stupid here? :unsure:
  • Kevin P
    • 10812
    Most cable/satellite channels are only Dolby Digital 2.0 (2 channel + Pro Logic). Your best bet for finding 5.1 sound on satellite is on the movie channels (HBO, Showtime, etc.).
    Does the NAD display the digital signal format (PCM, DD, DTS, etc.)? You might have to go into your satellite box's setup menus to enable Dolby Digital through the digital output. It could be converting everything to PCM stereo.
    • Paul H
      • 904
      If you haven't already make sure that you check all the audio settings on the digital cable box. For example, the default on the one I have was set to 'high compression' for all audio, which put out sound quality a shade worse than fm radio.
      Different cable boxes and cable suppliers will no doubt provide different results, but I can't say I'm impressed by cable sound quality that we get here after all the settings were optimized.
      Paul
      • Charl
        • Apr 2004
        • 50
        Thanks for the suggestions guys. Kevin I'm not sure, will check.
        I'll experiment some more and see how it goes.
        • Brandon B
          • Jun 2001
          • 2189
          You don't say which satellite service you have, but DishNetwork hhad labeled PPV movies in 5.1 DD in the onscreen guide last I looked.
          BB
          • Charl
            • Apr 2004
            • 50
            BB our local serive here in South Africa is called Multichoice DSTV. This is Africa, so I'd be verrry surprised if any of the channels or services are in 5.1.
            I thought the whole idea of DPL or PDLII is to decode a 2 channel source into 5.1?
            • brucek
              HTG Expert
              • 303
              I use the ExpressVu satellite system and when a movie is in 5.1 the guide tells you so, but they also let you know before the movie with a cool THX type intro that circulates around the channels.
              I would put the audio quality only slightly below DVD. I find it very good.
              The movies that aren't transmitted in DD5.1 are DD2.0 - On these movies I use prologic - quite good sound, no complaints..
              • Charl
                • Apr 2004
                • 50
                I've played around a bit and also queried the tech dep of the manufacturer. All sources (cd, tuner) sound fine to good in any format, it's just the dstv that keeps giving a 'warbled' sound in any surround format. And this seems to be much more pronounced with voices.
                The tech dep don't know anything about the digital output on the box, apart from that it 'improves sound by 10%'. That helps a lot.......
                Unfortunately all sat channels are only 2.0 here in SA.
                Seems we'll be watching tv movies in stereo only then - bummer! :M
                  Twin Moderator Emeritus
                  • 16706
                  Is it possible you're not muting your TV when listening through your HT setup? This will cause that "warbled" sound especially with the centre channel and TV which would explain why it's most prevelant with voices...
                  • Charl
                    • Apr 2004
                    • 50
                    Jason I'll check when I get home tonight, but I'm sure I have the volume turned all the way down, but not actually muted. Can this make a difference?
                      • 16706
                      Even if your only getting 2.0 you should still be able to listen in DPLII surround.
                      If you're turning the volume all the way down and there's no output, that "shouldn't" effect the sound... Is it possible your centre and or other speakers are wired out of phase? Double check all your connections to make sure no negative or positive wires are reversed at the speakers or your amp.
                      Do you have any stereo sources (ie: a 2.0 DVD or a CD with lot's of talking on it) to confirm that other stereo sources when played in DPLII do or don't do the same thing? Have you tried adjusting any of the DPLII parameters or trying the different music/cinema modes? Don't be afraid to try the music one on TV/movies and vice versa...
                      • Charl
                        • Apr 2004
                        • 50
                        I appreciate your help and advice Jason. Will play more over the weekend.
                        • Charl
                          • Apr 2004
                          • 50
                          OK, so we've finally identified the source of the problem. I contacted the import agent about a problem with intermittent humm and the odd 'popping' sound. He conceded that NAD have identified a problem with the 'new' T163's and asked if I also experienced a strange 'whistling' sound when listening to digital formats such as DPLII. Bingo!
                          So there we have it - another expensive piece of equipment with a manufacturer's fault. It really makes me mad to see so many posts about problems with brand new equipment from reputable suppliers.
                          Yes it's great that "might" send me a replacement unit (not fix), but faulty models should not pass their quality control in the first place! Not so often anyway. :rant:
                          By the way, when I bought this unit 3 weeks ago it was the latest release version - or so I was told. Surprise, there's a newer version available now, but if I want the next version with DPLIIx I'll have to wait another month!
                          So we already have 4 diferent versions of a product only released here 2 months ago. :M
                          I do appreciate your attempts to help with my problem.....thanks guys!
                            Philips 32PT830H
                            by aud19
                            So our office got together and got this Philips 32PT830H for a coworker for a house warming / help out (husband lost job and their TV blew up) gift.
                            It came to just under $700 Canadian, after taxes through our supplier :E A price I can still hardly believe!...
                            08 July 2005, 19:06 Friday
                            List your Digital gear!
                            by PewterTA
                            I figured we might as well start of with this simple topic to get people started!
                            Right now, here's how my data flows from my server to my stereo.
                            Server used for storage, it's a "simple" MS Windows 2k8r2 box with a BUNCH of storage. Everything in my house is ran...
                            26 May 2013, 10:44 Sunday
                          • gshisme
                            Optical vs. coaxial digital for the 1066
                            by gshisme
                            I have been using digital optical cable for both my DVD and HDTV satellite receiver to connect to the 1066 and my dealer yesterday told me to throw away my optical for coaxial. Huh? Everything I have read points me to optical cable. Any comments on optical vs. coaxial cable use.
                            Greg...
                            26 May 2003, 13:31 Monday
                          • stevecuss
                            sound quality of rsp976 verses rsp980?
                            by stevecuss
                            Hi Folks,
                            I have an older RSP-980 surround processor driven by an RB980BX 2 channel amp. I run a pair of kit speakers and a powered sub and use it for music, tv, dvd etc. I'm very happy with the sound quality, but the processor is pro logic and not digital.
                            A local...
                            29 March 2009, 17:27 Sunday
                          • jrhodus
                            Please Help: Sound delay with rsx 1065
                            by jrhodus
                            Hopefully, somebody can help me with a problem anf a solution.
                            I have a Rotel 1065 receiver and a Zennith hd 520 high def OTA/Direct TV settop box. The Zennith connects to the Rotel using a Opital digital cable for sound. When I change channels I have a 2 to 3 second delay where there...
                            19 September 2003, 11:41 Friday
