I need your help...
  • ice cube
    • Jan 2015
    • 24
    I need your help...
    I have a pair of B&W CM9, a pair of CM5 and CM2. SUB JAMO660 (5.1) Denon 4520Ci, Room size (4x4) Mete not Feet. What is the benefit of having Processor + Amp and AVReciever in my room. If the amp is going to add more watt >> in my opinion I don't want extra watt but if the Processor + Amp will give clarity , detailed sound or warmth I would have Processor + Amp but if it is just an extra watt I don't need them just Denon 4520Ci is enough correct me please. if you will say take Processor + Amp (what do you recommend) Nad pre + ATi Amp or Rotel pre + Ati amp or any thing else I appreciate your help Bye Bye
  • madmac
    • Aug 2010
    • 3122
    Hey Ice man!
    Well, some will say that separates will perform better than a receiver but that all depends what you are going to do with the system. Are you an 'audiophile' that critically listens to a lot of music with the system or are you mostly a home theater person? Your room is very small with a 12x12 foot listening area when roughly converted to feet. It also depends on how large your pocket book is as well.
    Dan Madden :T
    • John Holmes
      • 2707
      Welcome to the Guide, ice cube!
      You state that power isn't an issue. From what I gather from your post, you're pretty much happy but feel there is still more to be had???
      My personal experience has found, the biggest and "usually" best improvements come from good speaker placement and solid calibration. I've had a few receivers and pre/pro + amp combos over the years. All have had their strength and weakness. If you listen at modest or slightly above levels, I'm pretty confident the Denon is more than up to the task. The load of the speaker and the levels you want from them in a given space will dictate the need of an external amp.
      Sound is so personal and subjective, only you can really say if a pre/pro + amp will make a difference. You have very nice system, many would be more than happy with.
      • Ovation
        • 2204
        I agree, it's already a very nice setup and for a room that size the power is plentiful. If I were in the OP's shoes, I'd experiment with speaker placement and run Audyssey with each new placement until I got the sound I wanted. A real time room analyzer (REW is an excellent free one available online) with a decent mic will cost a lot less than new gear and will maximize the effectiveness of Audyssey and speaker (especially the subwoofer) placement (I speak from experience though with a different EQ system--same principle applies though).
        • ice cube
          • Jan 2015
          • 24
          Thank you all .. I don't want to waste my money .. But if I want to change my Denon 4520ci. Right now I am thinking of Atoms ... What I want is Denon 7200 or Marantz 8022 + amp. What do you recommend.
            Twin Moderator Emeritus
            • 16706
            Separates offer a better upgrade path in the future (you only need to re-buy a processor and not an amp too) and generally offer more power and better dynamics than receivers.
            That said, receivers generally have more bleeding edge features, lower initial investment and would likely offer "enough" power for your smaller room.
            It's really your call as to what's more important.
              • 16706
              Originally posted by ice cube
              Hello, thank you for your reply on my thread..
              My Q is .... Is it really worth to have separates.
              I have B&W CM9,CM5,CM2, ASW10CM SUB5.1, and Denon4520ci.
              This AVR is my mistake, I discover after 1 year that it is not driving or giving me more Watts. And the integra 70.6 is the best mate as AVR. Smooth, clear, detailed, bright and has worm sound. Are there any separates going to give me more than integra. If separates will give more ... How much... 6% .. I don't want to upgraded just for even10% ... What do you think.
              Unfortunately the only person who can answer that is you. I don't know what your personal finances are like or what your system sounds like in your home, to your ears.
              Having said that, generally speaking, even the best of receivers have trouble supplying the kind of power and clarity that a quality separate amp can with it's own dedicated power transformer(s) and isolated circuitry. If you're serious about this hobby, a separate amp is almost never a bad idea. And you already have good quality speakers to take advantage of extra power.
              Your Integra unit looks like a pretty nice piece of kit but if you're already finding it's power lacking a separate amp is probably the most likely upgrade. You can still use the Integra as a processor (utilizing its pre-outs to the amp(s) ), heck you can even still use it to run the surround channels and just amplify your mains and/or centre speaker.
              So that leaves you with a few options IMO. You could get a two channel amp to power your main left and right speakers and let the Integra power the rest. Or you could get say a five channel amp, bi-amp your mains and power your centre speaker with the amp and leave the Integra to power only surround/effects channels. As a final option, you can get one or multiple amps to power anywhere from five (I see that the Integra is Atmos ready) to eleven (or a whopping 13 if you have a full Atmos suite of speakers AND want to bi-amp your mains...and money to burn :lol: )
              Personally I'd probably go with the second option of a five chanel amp powering your centre and bi-amping your mains. As for which make/model...that will depend highly on your budget and secondarily on where you're located.
              Otherwise, I second (third?) the recommendation to experiment with speaker placement, calibration...and room treatment. But it's hard to say for sure what you need without knowing exactly what you find is lacking.
              • ice cube
                • Jan 2015
                • 24
                Thank you .. I have convinced.
                • extreme
                  How to use processor mode on Adcom GFP750
                  by extreme
                  I am having a problem with using the processor mode on Adcom GFP750. I connect the DVD player to my processor, and the processor connects its pre-out (line out) to the processor-in on GFP750. GFP750 connects to the Amp with the regular output. After I turn on the processor mode, there...
                  29 September 2005, 12:07 Thursday
                • extreme
                  HELP!!! How to use processor mode on Adcom GFP750
                  by extreme
                  I am having a problem with using the processor mode on Adcom GFP750. I connect the DVD player to my processor, and the processor connects its pre-out (line out) to the processor-in on GFP750. GFP750 connects to the Amp with the regular output. After I turn on the processor mode, there is...
                  29 September 2005, 13:41 Thursday
                  Adding a power amp to a receiver
                  by Andrew Pratt
                  As more and more people look to upgrade their sound systems people often ask about adding a more powerful amp to their system. Quite often this obsession we like to call our "hobby" leads us on a quest to sonic nirvana. As a group we are frequently upgrading our speakers or source components...
                  23 March 2002, 09:06 Saturday
                • windwaves
                  2ch amp with 5.1 pre ?
                  by windwaves
                  I have to start building some sort of a HT. All I have is a 42" plasma and my current two channel stereo.
                  What I am envisioning (wishfull thinking may be) is that I might be able to use my current amp (2ch, 100W into 8ohm and 150W into 4ohm) with a multi channel sound processor...
                  10 January 2004, 12:54 Saturday
                • june
                  6 channel inputs / outputs on Rotel Processor
                  by june
                  Hello All,
                  I want to add a pre-owned Rotel pre-amp processor in my bedroom. We are using a Yamaha rvx-3000 reciever. This reciever has the 6-channel inputs. Do any older units have 6-channel outputs? If so, we'll use the Yamaha for power only for the speaker. Will this work? We...
                  10 August 2005, 13:14 Wednesday
