HELP!!! How to use processor mode on Adcom GFP750
  • extreme
    • 7
    I am having a problem with using the processor mode on Adcom GFP750. I connect the DVD player to my processor, and the processor connects its pre-out (line out) to the processor-in on GFP750. GFP750 connects to the Amp with the regular output. After I turn on the processor mode, there is very week sound out of the front speakers with the maximum volume on the processor. If I connect the processor's pre-out directly to the Amp, everything works fine. My regular setup: CD player->GPF750->Amp->speakers works fine too. I can not figure out what is the problem on my setup, nor the tech support from Adcom. Could anyone give me a hand? Thank you.
    Extreme
  • Uncle Clive
    Former Moderator
    • Jan 2002
    • 919
    In which mode are you playing your DVD player (Passive or active) According to the Manufact. you're suppose to use the passive mode which would only allow the "Gain" control to work.
    So Line level outputs from DVD or to the Pre-amp input THEN Pre-amp out to Amplifier.
    Make sure you change the "audio Settings" in the DVD audio menu from "Bitstream" to "PCM"
    CLIVE
    • extreme
      • 7
      Thank you for your replay. I used both mode and no help.
      • junior77blue
        • 635
        I have the adcom gfp750 and am using it exactly as you described and it works just fine.
        I would double check the connections once again, there could possibly be something wrong with either preamp or the processor it self.
        I wouldn't think bitstream or PCM would make much of a difference since its the main speaker were talking about.
        What processor are you using?
        What DVD player are you using?
        • extreme
          • 7
          Problem is solved
          I have solved problem: processor-in actually means the output for GFP750 and same for the processor-out. Very confusion label from ADCOM and completely wrong diagram in its user's manual. Lossy job for Adcom!
          Thank for everybody's help!
          • Uncle Clive
            Former Moderator
            • Jan 2002
            • 919
            Good to know!!
            Now enjoy....................
            CLIVE
            • extreme
              by extreme
              I am having a problem with using the processor mode on Adcom GFP750. I connect the DVD player to my processor, and the processor connects its pre-out (line out) to the processor-in on GFP750. GFP750 connects to the Amp with the regular output. After I turn on the processor mode, there...
              29 September 2005, 12:07 Thursday
            • Rolyasm
              Adcom in Channel Protection Mode. Help??
              by Rolyasm
              My father was using an Adcom GFA 7000. He wanted to connect a sixth speaker to the 5 channel amp and thought he would try some crafty wiring. He took the speaker cable from the sixth speaker and split it four ways, connecting a pair to both left surround and right surround channels (thinking he would...
              30 September 2006, 16:47 Saturday
            • Aussie Geoff
              Secrets SSP (Surround Sound Processor) Benchmark Specifications
              by Aussie Geoff
              Thanks to Glenn, Club Rotel members were made aware of an interesting article by Brian Florian in the “Secrets of Home Theatre and High Fidelity” Web site titled “The Secrets SSP (Surround Sound Processor) Benchmark Specifications”.
              The link to the article is http:
              25 November 2003, 09:27 Tuesday
            • pras1011
              Rotel processor VS Adcom proccesor
              by pras1011
              I have a rotel 1068. but in silly quest to go forward with bigger and better processors, i came across a Adcom 860 pre-amp. adcom are unknown in the UK but i am hoping you people in the US have knowledge of the 860.
              So people which one is better?
              thanks
              Pras
              25 December 2005, 05:29 Sunday
            • PGAWest
              Receiver or Preamp / Processor Question
              by PGAWest
              Hello everyone - I'm new to the forum; not sure if this is the right place to post. I'm basically a newbie and pretty clueless in the home theater field, so I apologize in advance if what I'm posting is somewhat remedial.
              I'm looking for advice on a new receiver or preamp/processor....
              26 December 2005, 09:39 Monday
