Sony BDP-S550 hook-up for best sound
  • wettou
    • 3398
    Okay, I thought that buying a new blu ray player Sony BDP-S550 would simplify the hook up process etc, wow I was mistaken. I have an Integra Research RDC-7 that cannot process the new codecs but has analogue multichannel.
    The Sony BDP-S550 can decode it all until I upgrade to the SSP-800 when it comes out with the new codecs! Maybe someone here could confirm my settings for me.
    - Unit connected via the 5.1 analog connects
    - HDMi Audio: Auto
    - BD Audio setting: Direct
    - Dolby Digital set to: Dolby Digital
    - DTS set to: DTS
    - Audio ATT off
    If you have this unit have you made any other settings that may increase picture or sound quality?
    Thanks for any responses!
    Wise
  • M.Roberts8
    • 229
    I know this is an old one but I just stumbled across it.
    That's how I used mine with my Denon AVR-3300 and as long as your receiver can do pcm you should be good.
    Also set the Audio priority(BDP-S550) to "multi-channel analog outputs"
    The BD Audio has to be set to "direct" in order to get the TrueHD and DTS-HD MA tracks. You can check if you are getting them via the "display" button on the remote. It should tell you what track you are on in the upper right hand corner. Also some movies default to the core DD 5.1 Track so always check at the beginning of the movie.
    I had to mess around quite awhile in order to get the DTS-HD and the TrueHD to show up. It's definitely the BD Audio setting. If you switch it to mix you lose the DTS-HD and TrueHD tracks. Their description is vague IMO.
    As far as the picture goes if you have HDMI and a 1080p display that's as good as it gets as far as I know.
    • june
      • 907
      wettou,
      i have the sony hooked up to a rotel rsp-1066 via 6-channel analog outputs with the audio settings on multi.
      while a bluray is playing, press the display button & you'll see the sound playing.
      June
      • wettou
        • 3398
        Originally posted by june
        wettou, i have the sony hooked up to a rotel rsp-1066 via 6-channel analog outputs with the audio settings on multi.
        Thanks I returned it and got the Panasonic for $200 :B I am waiting for the Oppo BDP83
        • june
          • 907
          wettou,
          remember with the panny 55, you must press the audio button twice to get the new hd surround sounds.
          June
          • wettou
            • 3398
            wettou, remember with the panny 55, you must press the audio button twice to get the new hd surround sounds.
            Is it the same for the 35
            • wettou
              Sony ES new Products SCD-XA5400ES
              by wettou
              Sony Delivers the Ultimate Home Cinema and Multi-Channel Music Experience With Its Latest ES Family of Products
              Three New Products Combine to Give the Very Best in HD Home Entertainment
              BERLIN--(Marketwire - August 28, 2008) - IFA
              -- High-end system of Blu-ray Disc...
              28 August 2008, 17:30 Thursday
            • wettou
              Competition for OPPO BDP-83 Sony BDP-S470
              by wettou
              Sony's $200 BDP-S470 is company's first 3D-ready Blu-ray player
              And the flood gates are now officially open. Just hours after Panasonic introduced its newest 3D Blu-ray recorders and players, along...
              11 February 2010, 16:47 Thursday
              Which new HD audio format should you use?
              I thought I'd post this to help out those who have taken the plunge into HD-DVD and/or Blu-Ray, to understand the BASICS of the new HD audio formats that it includes.
              The question is, when I pop in a new HD-DVD or Blu-Ray, when I get to the main menu, I've got a choice of several different...
              14 May 2007, 03:06 Monday
            • brucek
              SONY DVP CX777ES Review
              by brucek
              In a quest to organize all my CD's and DVD's, I decided to purchase the new 400 disc multichanger from Sony. This was introduced last October as the first mega changer that Sony has adorned with its 'ES' moniker, and I have to admit that all-in-all it does deliver excellent video and audio.
              21 July 2004, 13:10 Wednesday
            • oxcartdriver
              HDMI connectivity problem, Integra DTC 9.8 w/ Sony BDP-s350
              by oxcartdriver
              I'm having connectivity problems with my Integra DTC 9.8 and Sony BDP-S350 using an HDMI connection.
              S350 is setup as DVD, HDMI input #2
              Comcast box setup as CBL/Sat, HDMI input #1
              Signature:
              Sony BDP-S350 will not show video or voice when connected through...
              28 July 2008, 13:23 Monday
