Regarding PureAV PF60 bank. HELP!
  • kobestonecold
    • 149
    Hi, which bank should i connect my equipments to?
    1. Onkyo AV receiver TX-SR604?
    2. B&W subwoofer AS2?
    3. Rotel Rb-1080 Power Amplifier?
    ;x(
    • 16120
    I'd probably plug the sub into High Current and the receiver and amp to Audio Filter 1.
      • 3815
      Plug the receiver into the one labeled "receiver".
      Plug the amp into one of the two labeled "amp".
      Plug the subwoofer into one of the two labeled "amp".
      -Chuck
      • kobestonecold
        • 149
        ok. Thank you
          • 16120
          Didn't see those labels...
          • kobestonecold
            • 149
            I read the manual regarding program the socket banks but i don't understand what the benefit of it?
            A. Socket banks always on (unswitched) . This one good for DVR, satellite.
            B. Socket banks Switched on (no Delay) . What about this one? What is it good for?
            C. Socket banks switched on after delay . HECK? I am confuse.
            Please explain what the benefit of each programmable. You can read it here
            Program the Outlet Banks
            Each outlet bank on the rear panel of the Power Console is programmable.
            Using the slide switches on the rear panel, you can program the outlets for
            switched or unswitched, and for delay or always-on (no delay) (Fig. 2). You
            can also determine the length of the delay (5, 10, or 15 seconds).
            A. Outlet Banks Always-On (unswitched): For components that need to
            retain memory or other settings (DVRs, satellite receivers, VCRs), set
            the top slide switch to “Always ON” (Fig. 2a). These outlet banks will
            always supply power when the Power Console is plugged into the wall.
            B. Outlet Banks Switched On (no delay): Set the top slide switch to
            “Switched”. Make sure that the lower slide switch is set to “No Delay”
            (Fig. 2b). The outlet banks will be immediately powered-on when the
            Power Console is switched-on by pressing the “Switched” button on the
            front of the unit. Switched outlets can also be switched-on by external
            remote signal (see page 10-11). These outlets will remain powered-on for
            a short period of time after switching them off depending on the “Delay
            Time” setting (see “Delay Time Switch” below).
            C. Outlet Banks Switched On After Delay: You may find it necessary to
            program your outlets to switch on after a delay. Once the delay is set,
            the outlets will be powered-on after the outlets that are set for “no
            delay” have powered-on. They will then power-off in reverse sequence:
            “delay” outlets will power-off first and “no delay” outlets will power-off
            last. This is useful to avoid the loud and occasionally damaging speaker
            “thump” created when the amplifier voltage is stabilizing.
            • JeremyG
              Belkin PureAV PF30
              by JeremyG
              I've been looking for a power conditioner/suppressor for some time, but can't commit. I hear a few people here use the Belkin PureAV PF60's. Anybody use the PureAV PF30? It looks like it may have most of the same features. Amazon has a killer deal on it right know. I guess my concern is if it uses...
              03 May 2010, 19:20 Monday
            • hugexpat
              RSX 1055 Voltage change (Help)
              by hugexpat
              Hello
              I own a RSX 1055.
              I have to move back to France ( everything has an end..)
              I have been told that the Rsx 1055 can be easily modified by switching some jumpers located in the left end corner (chassis opened)
              I found the jumpers. There are three of them,...
              11 April 2007, 16:51 Wednesday
              Exploring Common DIY Terminology - Phase Plug
              by technodanvan
              Phase Plug
              A phase plug is a stationary structure placed at the center of the loudspeaker driver's diaphragm, just in front of the voice coil. It is typically a cylindrical or conical-shaped object made of materials like plastic, metal, or wood. The phase plug's design may vary depending on the specific driver and its intended application. Its primary purpose is to improve the driver's performance by addressing issues related to phase cancellation and dispersion. The function of the...
              19 July 2023, 18:28 Wednesday
            • Orange Peel
              Any worries/problems using cheater plug?
              by Orange Peel
              When I get my RMB 1095 I want to have it working right immediately, so I will buy a cheater plug before I get the amp, just in case I have the hum people get with this amp. If I use the cheater plug and plug it into the wall socket, what risks do I run doing this? Is it more prone to surging/blowing...
              12 November 2004, 10:35 Friday
            • tmt
              what kind of speaker plug should I use? (kinda B&W related :)
              by tmt
              In one of my previous posts I mentioned that I moved in with my girlfriend, until my house has become a reality (in a year or two).
              My 802s can fit in the bedroom, but there is no place to put the amplifier near the speakers, the only free place has a door in between the amp...
              31 January 2006, 07:24 Tuesday
