Just bought my first house and can finally run the speaker wire for the surrounds in-wall. For longer runs should I use 12 or 14 guage? Normally I just use 12 guage but got to thinking about it and wondered how distance factors into it, if at all.
Guage for In-Wall Speaker Wire
Hi Pez,
Use 12-gauge. 14-guage might be okay right now, but what happens if you upgrade later to a surround speaker that requires more juice to drive it? The few cents more it'll cost you is far outweighed by not having to redo the runs later..
I used 12 gauge in the previous house that I owned and wired, and it worked great. David got it right--14 is good enough, but anytime you do something in-wall during construction, you want to do it right with overkill, and future-proof it.
12 gauge is no extra work to run, almost as easy to work with, and costs little more than 14 gauge. But it will be more than sufficient for your current and future needs. Those who a few years ago ran some extra runs of Cat 5e or Cat 6 cabling are sure counting their lucky stars now to add new technologies, for instance.
- Pleasantville- Bottom
Originally posted by Chris DI used 12 gauge in the previous house that I owned and wired, and it worked great. David got it right--14 is good enough, but anytime you do something in-wall during construction, you want to do it right with overkill, and future-proof it.
What about 2 vs 4 conductor wire (assuming with with 4 conuctor twisting two pairs together). I know using the 4 conductor with the bring the guage to 9 but can I just go with 2 conductor? Are the advantages worth going with 4 conductor?- Bottom
by Hdale85I was going to order some speaker wire from PE and was just thinking...How much does the guage of the wire matter? I was going to buy some of their 10ga OFC wire is that a lot of overkill? Would 12ga be just as good? Just thought I would ask before I purchase.-
Channel: Mission Possible DIY
by deuceleehey guys, i'm ready to start buying some speaker wires...
i got a onkyo 805 coming and will be building a set of RS WMTW centers and WWMT's for the fronts with a set of medula MT's for the rears...
my receiver is about 50 and 40 feet from the fronts, 45 feet from the center,...-
by rich0372I have 35' of wire to my surrounds is 14 guage wire enough or would 12 guage be better Thanks Rich-
Channel: Audio Hideout
by StockinvI'm in the process of putting together an HT system with 802D's as my mains and HTM2D as my center. Since I'm a relative newbie, I'm not educated in speaker wire. What should I be looking for? Is there a certain minimum guage wire that would give these speakers their best performance? The guy putting...-
Channel: Club B & W Speakers
by RobHello,
Im considering buying better quality interconnects and speaker wire. I currently have Monster interconnects (about $35 apiece) and 12 guage Monster speaker wire.
I thinking of spending about $750.00 on interconnects.
Will better interconnects be a great difference...-
- Loading...
- No more items.
