Buzzing sound from Krell HTS
  • bayou
    • Jun 2007
    I hear a buzzing sound on all the inputs from my Krell HTS. I bought this couple of months ago and hooked it up only now.
    Setup:
    The ac outlets are all properly grounded.
    Krell HTS is connected to a ac outlet with a 3 prong power cable.
    Rotel RMB-1095, also connected to a ac outlet with a 3 prong power cable.
    Krell and Rotel are connected (only R and L front channels) with a pair of Monster RCA cables.
    Rotel is connected to a pair of B&W 705
    A CD player is connected to Krell's coxial digital input
    To identify the culprit, I connected Krell to an old Sony amp. and I hear the buzz. Also, I tried another CD player with no change.
    The moment I start playing I hear a buzz along with the music. The music is definitely louder than the hum. When I pause the CD, all I hear is buzz.
    When I switch to Tape (analog) with or without connecting my tape player, I hear the buzz.
    Can anyone help please?
    I am an experienced user and have covered the ground or so I think. Hope I am missing something and is not an issue with Krell. I don't even want to think how much it is going to cost me to send it to Krell for repair.
    Any input is highly appreciated.
  • John Holmes
    • 2707
    Welcome to the Guide bayou!
    Since you been in the hobby for awhile I'm sure you've also attempted to check all wire by removing one at a time. But, from your post, it does seem that the problem may very well be with the Krell itself.
    BTW, Nice gear. :T
    • subynube
      • Apr 2007
      • 104
      Remove the coax cable from your TV, and see if the buzzing goes away. If the cable is not grounded properly, then the system will buzz. This just happened to me in my new apartment, so I bought a cable ground isolator for 10 bucks at parts express and it went away. Hope this helps.
      • OttoMatic
        • Jan 2007
        • 34
        Perhaps it's a ground loop issue. Try lifting the ground plug of the Krell with a cheater plug.
        -- Otto
        Misc Pics
        • pciav
          Need Help/Advice - RSP-1068 Buzz/Hum
          by pciav
          I've owned my RSP-1068 since July of 2004. My boss and I purchased units at the same time from the same dealer. In general I love it. I paired it with an ATI 1806 Amplifier and everything has been great until just before Christmas when I first noticed a buzzing sound. I say buzz, because I liken...
          20 January 2005, 22:03 Thursday
        • jimmyp58
          Buzzing After Moving Components
          by jimmyp58
          I am in the process of getting a new A/V rack but until I settle in on which one to get, I had to take care of the WAF with my current rack/layout. I have two tower racks currently, each one flanking my RPTV/HDTV. Each tower has a series of components plugged into a Monster Power HTS 5100; each 5100...
          19 September 2003, 02:57 Friday
        • Jay Sylvester
          RSX-1067 buzzing with only speakers connected
          by Jay Sylvester
          A few weeks back, I purchased a 1067 receiver from my local dealer. When I hooked it up, I heard a distinct buzzing sound coming from all the tweeters in my system. The buzz was volume dependent, but still quite audible at very low volumes. Since it was coming from all 7 speakers in my setup, it was...
          17 November 2004, 16:48 Wednesday
        • mitch57
          RMB-1095 Buzz
          by mitch57
          Hi all,
          My 1095 seems to be buzzing more and more these days. I have verified that it's nothing to do with grounding. The buzzing is coming from the amplifier itself. I disconnected all interconnects except the speakers.
          Here's what happens:
          1. The amp...
          11 March 2005, 10:42 Friday
        • See-Fu
          RSX 1057 buzz, HELP.
          by See-Fu
          My equipment consisted fo the follow before I added an amp.
          RSX 1057, TV, Xbox 360 & DVD player. SPeakers were B&W 603 and a LCR600.
          WHen I had this setup everything worked out fine, no buzzing. However once I added a Krell amp, I started to notice a buzzing noise...
          09 December 2006, 16:58 Saturday
