PANAMAX 5510-PRO Power ACRegenerator. Any one ever used it.
  • locomk
    • 91
    I also posted this under the Audio hideout. Currently i'm using a monster mphts3600 filter. wondering if i should upgrade to the panamax piece which has ac regenaration.
    info on the piece is here
  • Vinny
    • 252
    For the spec I would say it's about a lateral switch or a minor upgrade. As you already have a Mon$ter unit, pursue another level of surge protector/line conditioner would be more beneficial. Think about RG or/and zerosurge perhaps?
    RG does have decent line conditioning technology and zerosurge has outstanding surge routing advancement(they aren't really surge surpressor like other brands anymore but a different way of routing the surge).
    Pioneer KRP-500M
    Emotiva UMC-1
    Parasound 5125
    Oppo BDP-83
    Klipsch RF-3II, RC-3II, RB-5II
    SVS PB-10NSD
    • Kal Rubinson
      • 2109
      Almost(!) a lateral move but the 5510 incorporates a low-voltage sensor and shut-off which the Monster lacks. In cases of brown-out and/or intermittant outages, the 5510 will disconnect your equipment from the line and prevent the flipping between on/off which can damage equipment. I used this model for about a year and it did function reliably as described and, for that, I am grateful. Went to an APC S-15 from there to get, among other things, a UPS capability.
      Kal
      Kal Rubinson
      "Music in the Round"
