Okay. I have a general purpose combination media/sports room on the second floor of my house, which is being built as I write this. The two sections of the room are "separated" by a step down from the sports/bar area to the theater area. The total size is 40' long by 25' wide (in most places).
I have 2x4 staggered wall construction along the inner wall shared with the "private space" of the second floor, e.g. two bedrooms. The entire space is insulated as well.
I am having the builder put double 1/2" drywall on ALL walls and ceilings in this room. In between layers of drywall will be GREEN GLUE.
My question is this: I have two options for the floor. 1) Put green glue down on the subfloor and put another 1/2" subfloor on top or 2) Have the ceilings of the rooms on the first floor below the theater/sports areas double drywalled with green glue.
Can you all provide some suggestions? Any comments here?
Regards
Shane O'Neill
Regards
Shane O'Neill
