Announcement
No announcement yet.
Interesting
They have been around for several years. I don't really see the point , myself. A properly set up tonearm and cartridge put very little pressure on the record. And for that kind of money I could put together a very nice vinyl rig.Lee
Originally posted by madmac View PostIf a laser beam is picking up the records information I don't see how the whole process could be analog??
Now if they took the analog signal "read" off the vinyl by the laser and ran it through an ADC to make it digital, DSP to condition the signal, and then back to analog with a DAC, then there would be digital in the signal path, but according to the article, they don't do that. It's just as analog as a traditional turntable.
No more so than converting the mechanical vibrations of the stylus scratching the surface of the disc. There is no analogue to digital conversion happening in the mechanism (just like Laserdisc players were analogue video players).
Originally posted by madmac View Post" converting the groove vibrations into an analog audio signal "
Meaning that initially it's a digital interpretation of the groove modulations no ?
Originally posted by Kevin P View PostNope, analog. The laser reflects off the groove and hits a phototransistor. The vibrations in the groove reflect the laser in different directions, causing its intensity on the phototransistor to vary, and thus the output from the phototransistor varies accordingly. It's a direct analog representation of whatever the groove contains, so, it's not digital. Instead of a stylus, coil and magnet creating the signal, it's a laser and phototransistor circuit creating basically the same signal, using light reflection to create a voltage rather than mechanical vibrations. Optical/electronic instead of mechanical but the result is still analog.Dan Madden :T
Originally posted by madmac View PostFascinating !! However, with a price tag of $15K , we might as well spin vinyl the old fashioned way!
If I drop $15k on a vinyl rig I'm going to want to pick my cartridge , set it up and align it , fine tune it , set the tracking and the weight , level the table , and then enjoy the fruits of my labor. Playing with the gear is part of the process for me.Doesn't mean the laser thingy is bad , just that it isn't good for me. I suspect I'm getting old.
Every time a record is played on a conventional rig with a stylus riding in the vinyl groove, microscopic wear & damage is taking place.
Over time, this process will cause audible damage/distortion.
The beauty of this devise is that there is no physical contact with the record groove.
Thus there is no wear & subsequent damage/distortion to the vinyl.
Your vinyl stays pristine regardless of the number of plays.
This is why many of us vinylphiles digitize our vinyl libraries.
