SACD analog interconnects
  • sharnyo
    • 17
    Just got a new SACD player - Marantz 8260. Currently, it's setup as 2 channels using my old Monster 300 audio interconnects.
    I am thinking of getting more interconnects to get the 5.1 multichannel working. Is there a difference between using the specially-designed SACD interconnects (5.1) or just get 2 more pairs of analog interconnects ? If it doesn't make a difference, is it sonically alright to mix interconnects from different makers ?
    Thanks.
    • 16060
    Thanks.
    Well, if you're running multiple speakers, are they identical?
    Different interconnects do have their own signature, but it tends to be a lot more subtle than different speakers. I've never heard of any specially designed multi-channel interconnects for 5.1- who's offering those? I'd expect good quality analog interconnects to do just fine. Are you running this through your HT setup into a 5.1 analog input on your receiver or Pre-pro?
    ~Jon
      Twin Moderator Emeritus
      • 16706
      For the sake of continuity I'd just order a new 5.1 set. I'm sure you can use those other cables somewhere else in the system
      Check out the link at the bottom of the page for Cat Cables. Doug will put together some nice cables for ya for a decent price
      • sharnyo
        • 17
        Monster has a 5.1 cables for SACD, and also Wireworld rainbow 5, Van den hul The Bay C5. There are increasingly more manufacturers that cater for these SACD cables.
        I just wonder whether these are designed differently. My logic tells me that it shouldn't be different from regular analog interconnects, perhaps maybe for the subwoofer connection for its low freq.
        Yes, my speakers are all from the same manufacturers ie. B&W 600 models in a 5.1 HT configuration.
        • theMaximus
          • 179
          SACD/DVD-A cables from Monster Cable is the same as their analog interconnects (400 MKII). As far as I know, when they package it as SACD interconnect set, they are currently available only in 2m length, where as if you bought three separate pairs of 400 MKII, you can by them in other lengths. Another thing is that you don't save any money by buying it as a package at $160 versus buying three pairs of 400MKII (2m length) at $50 per pair. I would save money by buying three separate pairs of 400MKII (1m length) at $40 per pair. Another option is buying Monster's more upscale M series cables (M550i) at $50 per pair, which is what I did. I generally stay away from Monster Cable, but M550i was an exception and got fabulous reviews by some Hi-Fi magazines (not that reviews mean everything).
          Or you can get CatCable, Ecosse, or Audio Quest cables, which have very good reputations.
          Victory Shall Be Mine!!! :heh:
          • NAV
            SACD and 7.1 Setup
            by NAV
            My current setup and problems when playing SACD:
            1. Cables (6) from DVD/CD's 5.1 Audio Outputs to C1's 7.1 Channel Analog Inputs
            2. Set C1 source to 7.1
            3. All balanced connections from C1 to Amps.
            4. All other sources work fine with all speakers
            Problems:...
            19 November 2005, 10:27 Saturday
          • Kevin P
            Denon AVR-3805 Mini Review
            by Kevin P
            I have the opportunity to try out a Denon AVR-3805 for a few days. I'll be posting my impressions here.
            Feature Highlights
            The 3805 is loaded. It supports all the latest surround formats, including Dolby ProLogic IIx, DTS ES Discrete/Matrix, DTS 96/24, DTS NEO:6, Dolby...
            08 April 2004, 08:49 Thursday
          • Mike Hayes
            DVDA/SACD Connections to 1066
            by Mike Hayes
            I am considering purchasing a Pioneer 563A ($180) universal player to replace my Toshiba SD5700. I am currently using just the digital connection (not using the 5 analog cables for DVDA). This will be my first experience with DVDA/SACD in conjunction with my 1066 so please bear with me.
            03 August 2003, 09:53 Sunday
          • gianni
            Rotel and interconnects
            by gianni
            I am looking for recommendations on some reasonably priced interconnects to use between my SACD player and my 1055. I usually use the digital input for CD's but would like to upgrade the analog side for SACD.
            I am using M&K speakers. I would prefer suggestions other than Monster and...
            01 March 2003, 02:56 Saturday
            Speaker cables...
            by Andrew Pratt
            Okay I know this is a taboo topic but its an interesting topic. I used to sit in the camp that was more geeker then tweaker in that I didn't believe that there were that great a difference between various cables. Maybe it was the lower quality of gear I had or just the cables I'd tried but I didn't...
            07 September 2000, 12:35 Thursday
