Highest SQ Crown amp for Bass
  • Brandon B
    • Jun 2001
    • 2189
    Input from all welcome, but curious about JonM/ThomasW's opinion on this.
    Still working on my speakers sloooooooooowly, but I have accumulated an amp collection. My question is: I have a Crown macrotech 2402 to drive my L & R woofers (Stryke Lmabda SB10's in a sealed 3ft box, XOed with a Marchand XM9 at 250Hz with accuton/focal 2 ways)). Amp is about 900 wpc at the 4ohms of the drivers. Plenty of headroom. Or is it foot room for a woofer?
    But it has a fan. This is not a huge issue as I have modified my room to have an innsulated AV equipment closet with forced air ventilation and a sealed door. But when listening to 2 channel music only, it would be nice not to have any noise. So I was wondering what the concensus was as to the sound quality of a Crown K1 compared to this amp, as I could sell it and get a new K1 pretty easily. I have seen some people saying the K series are crown's best, but that is not supported by the price. However, that price may reflect the extreme road durability and flexibility built into the MA series.
    K1 does have superior damping (3000 vs. about 1400 in the passband of my woofer).
    Or does someone have a better suggestion for about $1k, 700wpc into 4 ohms?
    BB
    • 16203
    Hi Brandon,
    I like the K series Crown Amps; Gerald Stanley's implementation of CLASS D with the opposed current half bridge is very innovative in the way it eliminates stress on the output devices from body diode conduction or overlap shoot through, while effectively doubling the output ripple frequency for a given power switch frequency. Furthermore, it is possible to interleave converter blocks and further reduce HF distortion without raising the actual switching frequency. (I work for a company that makes transistors suited for the K series amps, and have met with Gerald a few times)(I even own one of his first designs, the Crown IMA distortion analyzer).
    The Macro reference series is Crown's take on a very high performance conventional amp. Building this way requires more output devices, larger heatsinks, etc. For a given output power, it is more expensive to build. Also, the power supply is probably a little better optimized in the Macro series. (i.e., beefier).
    For LF duties, either amp will probably work well. I'm not really a big fan of pro "road" amps for bass systems in HiFi, because most don't have the power supply capacitance to really stabilize the rails under high current demands- in most cases, amps like QSC's, Mackies, etc., are built more to a price as much as a level of performance. Yes, they can have "slam" of sorts at high levels, but it's like comparing my old Phase 700 in the 70's with a modified Dyna Stereo 400 I built- the latter had 100,000uF of capacitance (4X the Phase Linear) and 100 uF of polypropylene bypass; (plus extra output devices and tweaked driver stage); it would shame our big Luxman and Stax Class A amps the Sound Gallery was selling. Power supply rail pumping on bass transients can create a more "dynamic" sound, in that things sound like they're working harder, but it doesn't create "ease". A really good system played loud should be deceptive; it shouldn't sound loud. Many of the "cues" we use for subjective volume are distortions of one kind or another.
    Also, damping factors in amplifiers are a lot of specsmanship. Reall world application is another matter. Damping factor is ratio of load impedance to the output impedance of an amplifier at the terminals. It doesn't include speaker wire. Even with my homemade Kimber cables, 14 ft, equivalent to 9 AWG wire, about 35 milliohms, will "limit" the actual damping factor (at the speaker) to about 225. If you "only" use 12AWG wire, you'll be lucky to hit 100. But most speakers are designed with an amplifier source impedance of 0.1 ohm or so in mind anyway, and changing this by 50 milliohms or so one way or the other won't make a meaningful difference.
    So, your Macro Reference amp should be fine. And it won't have the output HF ripple noise that the K2 will have. That could be a problem in some systems, re noise pickup. While I've always been fascinated with Class D amps, and built and wrote a few papers on them, I've never used one in my home audio system.
    Bottom line, I can't see any benefit to your exchanging your Marcro Reference for a K2. I think the K series are a pretty cool Class D implementation, but I don't think I'd use one for a full range amp, and I can't see it offering you any advantages over your Macro Reference. If you needed another amp to drive a low efficiency sub like the Aerial Stryke 15, then maybe a K2 could be in your future.
    Best regards,
      Testing subwoofer tuning and playing with damping
      by ThomasW
      To do this method one needs.....
      1) a power amp, or receiver
      2) a DMM (preferably a TrueRMS unit)
      3) a method of generating low frequency sine waves (tone generators are easiest)
      4) a approx 100watt, 20 ohm power resistor (there's latitude with this value, so just...
      16 January 2006, 17:19 Monday
    • Glenee
      B&W 802D's and Crown K2
      by Glenee
      I am dealing on a pair of 802D'S but looking at the price range of the amps recommended on this forum, I was wondering if any one here had tried one of these amps on 802's. It has 500w@8ohms,800@4,1250@2. The frequency response is band limited with an 8hz double intergrated 3rd order Butterworth high-pass...
      27 August 2006, 21:39 Sunday
    • rdrowley
      Crown D-150A Series II Amp
      by rdrowley
      I was recently given a Crown D-150A Series II Amp. They are supposed to run ~95W into 8 Ohms. I cleaned it up a bit and plugged it in to run my front speakers. It runs super clean and it seemed like the music was more dynamic. It also seemed to open up the sounds on HT work a little bit.
      17 January 2011, 12:33 Monday
      New Parasound Z series half-width rack components
      Just got this press release from Parasound yesterday. You can Click On This Link Here for the official page from Parasound's PR firm.
      Parasound Adds Phono Preamp and Speaker Selector to Mini ‘Z–Series’ for Custom Installers
      SAN FRANCISCO (6/08/04)...
      10 June 2004, 04:05 Thursday
    • crazybastard
      Crown xs power amps on sale
      by crazybastard
      For those interested, Musician's friends have great prices on the xs series crown amps.
      xs500: $350 shipped
      xs700: $399 shipped
      xs900: $549 shipped
      If you've bought anything recently from Musician's friends, check your mail. I just got a letter of apology...
      28 December 2007, 17:15 Friday
