Just came across a local clearance center that has some AR Master Series 10G speaker wire for cheap. THe AR speakers cable features:
AdaptaTip: AR® exclusive, precision-machined 24k gold-plated AdaptaTip™ banana ends ensure the tightest connection possible
Solder-free: termination for maximum unimpeded signal transfer and accuracy
24kt gold-plated: Corrosion-free 24k gold-plated surfaces maximize audio signal transfer
10 gauge: separate alternating fine-stranded roped layers of oxygen-free copper and precious silver-coated oxygen-free copper for accurate reproduction of all frequencies.
6 mm cable signal separator: controls magnetic fields, allowing accurate sound reproduction.
My speaker setup consits of Paradigm Studio 40/20/570(v3) powered by a Rotel RMB-1095 hooked up with 16G AR pro series in Bi-wire config.
Kevin
Kevin
