DIY Two Way Towers (HELP!)
  • Stitches
    • Jun 2015
    Hi guys!
    I am in the design stage for a pair of two way tower speakers. This will be my first DIY so I would really appreciate some help along the way!
    I have chosen these two drivers:
    SB Acoustics SB26STCN-C000-4 (Tweeter)
    Silver Flute W20RC38-04 (Woofer)
    Would these drivers work well together, and would a good cross over be at 1600hz?
    I designed a 2nd order butterworth crossover.
Name:	1600Hz Crossover.gif
    C1 & C2- Solen 16uF 400V Polypropylene cap and Dayton Audio PMPC-1.5 1.5uF 250V cap (Together for 17.5 uF)
    L1 & L2- Jantzen Audio 0.56mH 18 AWG Air Core inductor
    Does this look good for a crossover?
    The woofer has a sensitivity 1.2dB higher than the tweeter so I designed this l-pad:
    R1- Dayton Audio DNR-0.51 0.51 Ohm 10W resistor
    R1- Dayton Audio DNR-25 25 Ohm 10W resistor and Dayton Audio DNR-2 2 Ohm 10W resistor (together for 27 Ohm)
    I don't think I need any notch filters because the fs of the tweeter is below the crossover point, and the fs of the woofer is below its effective frequency range. Is this correct?
    An online calculator recommended 15.97 liters as an enclosure volume, but I want more like 60 liters to make it a respectable sized floor stander. If I was to design it with a much larger volume than recommended, (60ish Liters), would it sound as good and have as good of a response? I would of course compensate with the port measurements.
    I would really appreciate any advice!
    Thank you guys!
    LR2 @ 1600 is too low for that tweeter. I would choose a smaller woofer.
      Post MOVED
      I have moved this post to the DIY section:
      LINK
      • joeybutts
        CJD Dayton RS Crossover BOM
        by joeybutts
        So I was reading over the thread and was studying the crossover and wanted to get a BOM for the center. A lot of questions arose, that I think can be answered by just listing the parts. I was wondering if I am overdoing some parts,
        One big question I had was that some of the inductors...
        24 September 2010, 12:01 Friday
      • jagstyle
        Modula MT project, work in progress...
        by jagstyle
        Images not available
        Parts Express BOM for one speaker:
        C1 12uF
        027-430 DAYTON DMPC-12 12uF-250V POLYPROPYLENE CAPACITOR $3.55
        C10 20uF
        027-436 DAYTON DMPC-20 20uF-250V POLYPROPYLENE CAPACITOR $4.95
        C7 8uF (4uF + 4uF)
        027-421 DAYTON DMPC-4.0 4.0uF-250V...
        10 November 2006, 02:46 Friday
      • lowark
        Capacitor and Resistor values...
        by lowark
        I am building Dennis Murphy's wmtw center and have a question on the capacitor and resistor total values. On the mid crossover bom there is a 7.5 and 50uF capacitor which need to equal 57.5uF. Also, there is 10 and 7 ohm resistor which need to equal 17 ohm.
        I understand on capacitors...
        22 December 2008, 11:55 Monday
      • johnson
        Modula MT project.
        by johnson
        Alright, this is the first DIY project in a while. I made the Adire KIT51 a few years back and a subwoofer enclosure last year. Got the itch recently and went ahead and ordered most of the parts for the Modula MT and got them today. Took out a lot of unnecessary stuff for the layout. All the parts should...
        16 November 2006, 16:30 Thursday
      • Hugo82
        Crossover component questions (Overnight Sensations)
        by Hugo82
        I'm planning on building the Overnight Sensations and i have some questions regarding the crossover components.
        I live in Holland and i can't get the Dayton components used in the original plan so i have to look for replacements and thats where i'm not quite sure what to get since the...
        18 October 2009, 07:45 Sunday
