AWOL Nation - Sail (on a Musical Tesla Coil)
    Ha ha... Pretty cool.
    Wow, that is cool indeed. How does that work? Initially, I would have guessed that there was some filament in the post that the coil is sending the charges to, creating an electrostat-type speaker. But it seems like that's not the case, that the discharge itself creates a tone. What are the physics of how that works?
    • Finleyville
      • 350
      Wicked!
      • Armand
        Replacing Seas Tweeter Voice Coil
        by Armand
        I'm expecting replacment VC's for SEAS H1212 tweeters and was wondering if there are any tips that you all can give me. I ask because I ran into this during a search:
        ""In case you ever need to replace the voice coil assembly of your tweeter, here is the procedure for re-assembly:...
        08 July 2010, 06:28 Thursday
      • Jay_WJ
        Steep slope XO prone to bad effect of voice coil temperature?
        by Jay_WJ
        I found the following article worth checking out. Here's a quote from it:
        "With passive crossovers, I now believe that anything over 12dB is a waste of time, especially when the effects of voice coil temperature are considered.
        Even with the second order filter, the possible
        24 May 2007, 12:11 Thursday
      • ligonk
        Issues with C-Coil inductors from Jantzen
        by ligonk
        I am using some C-Coil inductors from Jantzen for my Modula TMM build. Them, along with every other inductor and part get measured prior to using them in my crossover. Every other inductor i have measured in the past ends up being ever so slightly above the stated inductance, which is great because...
        16 August 2014, 23:20 Saturday
      • Audiophile100%
        Jantzen wax coil and Mundorf cfc coil
        by Audiophile100%
        some of you have tried them?
        wax coil have a darker color than the Mundorf
        Mundorf are pink instead of the wax are orange, is the treatment that changes the color?
        color of the Mundorf seems the real color of pure copper, while that of the wax no, like oxidized.
        wax coil are...
        17 January 2015, 05:18 Saturday
      • gonar
        stripping epoxy off of a coil
        by gonar
        I am making the Zaph B3S design and as part of the design, I had to unwind a .1 mH coil down to a .08 mH.
        so now the end of the wire on the coil is not the nicely factory stripped and tinned end, but epoxy coated wire.
        I sanded the end with emory cloth before soldering,...
        27 February 2007, 16:53 Tuesday
