Onkyo A/V receiver and 4ohm ZDT3.5's??
  • tylerdurden
    • 95
    Hi guys! This is my first post in the Audio Hideout. I have been spending my time in the Mission possible thread.
    I am presently building Zaph's ZDT3.5's and am looking to upgrade my gear if needed.
    I am wondering if my Onkyo TX-SR505 7.1 A/V receiver will power my 4ohm Z's.
    The manual says it is FTC rated at 110w per chanel, 8ohm loads.
    The only place in the amp section it mentions 4ohm is in the Dynamic Power section, "190w (4ohm, 1 ch driven)"
    I am new to this kind of thing and am really worried that it might be tuff on my Onkyo's amp. What do you think? Any suggestions or insight would be greatly apreciated!
    Bobby
    Oh I should mention, I want to use the Z's for 5.1 suround but also 2.0 audio/music. I will be building the ZDT center chanel and am asuming it will be a 4ohm nominal design as well. I will be using my OPPO DV-980h as a source for both music/movies.
    I think it would handle them fine. If not its always better to add a power amp :B
