Cd Player Noise Help
  • jpvnnvpj
    • Jun 2007
    • 34
    Hi ihave a sony dvp s9000es a have it from new and it youst estarted puting noise in my sistem. i chaged power cables and diconected the rca cables but everytime i plug it in noise estarts. i conected it to the wall, richard grey 400 pro and wit monster cable conditioner and nothing.
    thanks for any help
  • engr_dave
    • 112
    Is the noise present in the audio outputs or the digital output or both? Is it with all discs? Does it happen with CD's, DVD's, SACD's?
    If you are using analog connections, try engaging the "audio direct out" (button on far right side of front panel) which shuts down all video processing and unnecessary audio digital processing.
    It is not likely coming from the power line or power cord. Interconnects, maybe. Have you tried different interconnects?
    • jpvnnvpj
      • Jun 2007
      • 34
      Thanks for the response i have tryed difrent interconects power cables factory and jena labs it does it with or without disc on or off it only goes away wen you disconect power cable or rca. i even tryed other analog inputs on my rotel . i conected my oppo via analog and i does a difrent lower volume nois coudit be the reciver.
      • engr_dave
        • 112
        Almost sounds like a ground loop problem. Does it sound like a 60Hz hum or buzz?
        This often occurs when two interconnected components are at different ground potential. Do you have the CD player and the rest of the system plugged into the same outlet? You might try one of those ground-break "cheater plugs". Or try connecting the Sony using optical (Toslink) instead of RCAs
        • jpvnnvpj
          • Jun 2007
          • 34
          i hucked it up at difrent plases but same circuit i have a richard grey 400 pro and monste cable 2600mk.
          • zmanbands
            • 151
            Can you try a different receiver.
            Since you have a noise problem with your oppo as well, the receiver could be the problem. Can you try a different one.
            • jpvnnvpj
              • Jun 2007
              • 34
              Playing with the sistem noticed when i disconect the cable box coaxil noise goes away. passed it thru the mc 2600 and the noise almost went completli away.
              • GregLett
                Analog Power Meters.
                by GregLett
                Does anyone know who makes analog power meters, like the ones Macintosh uses, but smaller? I like the look, some fallout from the demo
                17 February 2006, 14:40 Friday
                Exploring Common DIY Terminology - Noise
                by technodanvan
                Noise
                In the context of loudspeaker measurements made during the design process, noise refers to any unwanted electrical or acoustic signals that can interfere with the accuracy of the measurement. Noise can be introduced through various sources, and it can affect the reliability and precision of the measurements, making it essential to minimize its impact for accurate loudspeaker evaluation. Sources of noise include:
                • Background Acoustic Noise: During loudspeaker measurements, ambient
                21 July 2023, 18:08 Friday
              • Nolan B
                Rotel Audio/Video Power Conditioners
                by Nolan B
                There are so many opinions and IMO lack of knowladge (including myself) when i comes to surge protection and line conditioners. I have a couple of questions about Rotels.
                I recently sold my Richard Grey because it did not do what I needed. In the end I did't expect to much from it because...
                21 April 2008, 22:59 Monday
              • GregLett
                Analog Power Meter
                by GregLett
                Hi I'm interested in adding an analog meter to my setup, like
                the Mcintosh amps. Can anyone point me to where I can purchase
                something like that, or help me build one?
                Thanks.
                21 February 2006, 09:22 Tuesday
              • jpvnnvpj
                Noise From My Rsx 1057
                by jpvnnvpj
                Hi i notice today that i am geting a humming noise from my maine speakers. i found that the noise is coming from my cd player a sony 9000es i changed power and interconects cables and nothing. i even conected a oppo ,the only way it goes away is if i disconect the power cable or interconects. :cry:
                11 September 2007, 17:51 Tuesday
