carver 4.0T magnetic field power amp
  • Paul51
    • 21
    does anyone know if this is a reliable 2 channel amp? how many watts per channel? and would it be a good addition to my RSX-1056 to drive my front speakers? any help as to magnetic field would be appricated.
    thanks paul
  • Thelonious Funk
    • 357
    Not a bad amp. Don't run it with a 4 ohm speaker...
    • alan289
      • Dec 2007
      I have had two of these amps since around 90-92, no problems with them.
      Rated 375W continuous per channel, or can be bridged as a single channel amp rated at 1000W.
      • rick c
        • 430
        why?
        • soundhound
          • Mar 2004
          • 816
          thanks paul
          1st they are thin sounding compared to your Rotel, which has been called "warm".
          2nd, if buying used, use caution, as I have seen many with resistor issues, (all of the TFM series I owned had issues) in which they were hacked back together, with destroyed traces, etc...
          Other than that they have been known to drive nails...................
          • AwArEnEsS
            May magnetic field of the B&W 685s give damage to dvd recorders?
            by AwArEnEsS
            I have a problem which I haven't been able to solve yet.About two weeks ago,I put one of the B&W 685's on a shelf,very close to the dvd recorders and satellite receivers.685 was not connected to the receiver(amplificator).After a while in the same day,the satellite receiver started getting locked.Then...
            17 January 2010, 18:13 Sunday
          • rick c
            Carver amp ?
            by rick c
            Ive seen on ebay a few deals on the carver amps.Some would say "magnetic field"others would say "high current"amp.What do these specifications mean.Dont mean to be ignorant i just dont know the differences between these and regular power amps.
            11 February 2005, 01:27 Friday
          • cameronthorne
            Magnetic fields and CRT TVs
            by cameronthorne
            I've heard Thomas say that the effects of a nearby unshielded midrange on a CRT television depend entirely on how far away it is from the TV, and how well shielded the TV itself is.
            Is it possible to test out the TV set itself without having a built speaker? How strong of a regular magnet...
            09 March 2007, 10:37 Friday
          • digitalshah
            B&W CM1 speakers sitting next to iMac 27" ???
            by digitalshah
            I am considering a used pair of CM1 speakers ( paired with a Rotel RA1062) for computer audio, converting old LP's to digital and general itunes listening. The manual for CM1's says that the speakers produce a magnetic field but the lcd displays are not affected. I am concerned about the speakers...
            15 December 2010, 12:01 Wednesday
          • bikedave
            Amp Issues
            by bikedave
            Ok, having some issues here. First off I will describe my setup. Right now I am running a line from the headphone plug of my computer into a Samson S-xover 2-way crossover. From there I go into my 2-channel Carver pro amp which is rated at 450watts a channel at 4ohm or 900 bridged at 8ohm. I've got...
            10 October 2007, 16:11 Wednesday
