Hi All
Just had a new TV/Hi Fi stand made out of pretty thick MDF. Looks nice, but my equipment sounded better placed on the floor, while I waited for the stand to be delivered. The obvious problem seems to be airborne vibration, giving the TV/Stand a bit of a shake and I'm sure you can imagine the rest...
My plan is to try, as best I can, to isolate the equipment from the stand itself, and I've come across a product called "VibraPod". Has (or does) anyone use these things or any other product that may yeild similar (or even better) results.
As an aside, I might want to place the actual components (a CD player, DVD player & very heavy amp) on a laminate glass sheet which will then stand on the VibraPods. Does it make sense to do this or is "less" actually better in this case?
Any comments will be appreciated.
