Ok guys, help me out here.
I have a Naim 5x with Flatcap power supply for the weekend trying to decide if it is for me. Its about 6 grand new in Australia, but these pieces are a couple of years old. Against it I have my 3 year old NAD T562 DVD player - $1,200 when new, both running analogue into a Nakamichi 2 channel pre/power amp (I disconnected my av receiver all together as I was surprised at the results I was getting). The Naim is benefiting from new Nordst interconnects, while the NAD is connected via some 2 year old X stream cables worth half the price at about $90. Speakers are a pair of B&W 804S. I have a level meter by my side to make sure that they are as closely matched volume wise as possible.
The difference, well the Naim is a bit punchier in the bass and maybe a tad clearer with vocals more prominent, while the NADs vocals are a bit recessed. Turn up the volume and the Naim can be a bit in your face, while the NAD sounds more pleasant in things like the vocals. The naim sounds a little more together, not that the NAD sounds bad. I have noticed that the 1 watt lights on the amp come on for the bass on the Naim, but are not doing so for the NAD - this may be because of the slightly more dynamic signal, or the levels may be a bit higher on the Naim. SPL meter says they are pretty evenly matched in volume.
Conclusion. Well I don't want to jump to one just yet. Am I doing something wrong? The Naim sounded so much better than the Quad CD player I compared it to in the shop. Now at home it is only marginally better than my DVD player (albeit a good "budget" player of CDs).
Is is really true that a 6K well respected CD is only a shade better than a 1.2K DVD? What else can I do to give the Naim a fair hearing? Only idea I have at this stage is to swap the interconnects.
Thanks in advance
Thanks in advance
When i auditioned my XT4's it was on an all Naim setup.
-Russ
