Need In wall speaker recommendations
  • GregLett
    • 753
    I'm looking for some in-walls for a friend of mine, not too expensive
    in the 1K range. It will be for an HT setup.
    Thanks.
    Greg
  • Snap
    • 1295
    Heck... Jamo K4 series would do. They have inwall Di-poles as well. They are introducing their A2 series with Di-poles some time this month. (A2 series are less than the K4) Great speakers! They come with a LIFETIME warr. as well! Very tuff to beat!
    These are great speakers. Use the L/C/R for a smoking system up front. Then use the dipoles.
    But Jamo will do you well.
    • GregLett
      • 753
      Thanks Snap!
      Greg
      • Audiophiliac
        • 346
        I like B&W in-wall speakers. Are you talking $1k for all speakers? Or just for a pair? Or each?
        • GregLett
          • 753
          1k for the main pair. He can get others later.
          Greg
