What DAC will work with a satilite dish?
  • Jeff
    • 281
    I'm interested in the Benchmark DAC1. It's my understanding it will only work with a pcm format.
    Is there any stand alone DAC which can also decode AC-3 format? It would be great to be able to upconvert the digital music channels as well as 2 channel broadcasts off the tv.
    Thanks, Jeff
  • locomk
    • 91
    not sure if any take ac-3, but you may be able to set your satelite box to pcm only and then use a dac, but satelite music channels are compressed and using a dac may not be better.
    • Jeff
      • 281
      You are correct! It's great when the answers your hoping for are true.
      I was under the impression that all satilite feeds from Direct TV were DD when fed through my new high def decoder. I was also told this from several individuals.
      Reality has proved otherwise.
      Upon further investigation, the music channels, which are XM radio, are all:
      16 bit
      48khz
      1536 kbps bitrate
      Catogory is identified as "broadcast-USA"
      When red book cd's are playing, they are identified as:
      16 bit
      44 khz
      1411 kbps bitrate
      catogory is identified as "CD-DA IEC60908"
      Regarding the information above, my Sony 777ES receiver provided this information. It provides this information on whatever input is being played.
      Based upon this information, it doesn't appear compressed. I'll admit I'm only 90% on the no compression thing. But so far it looks pretty good.
      Jeff
        A new DAC in the house
        by bigburner
        It’s an Oppo BDP-95 to be precise, which includes the highly regarded SABRE32 Reference ES9018 DAC from ESS Technology. The BDP-95 uses two ES9018 chips – one for the 7.1-channel output, and another for the dedicated stereo output.
        I bought the BDP-95 because I want to get into the...
        13 January 2012, 21:07 Friday
        Musical Fidelity V-Dac vs RME 9632 Soundcard Comparison
        by audioqueso
        Test Setup:
        Speakers: B&W Nautilus 805
        Integrated Amp: McIntosh MA6800
        Source 1: HTPC w/ RME Hammerfall 9632 Soundcard
        Source 2: HTPC w/ Musical Fidelity V-Dac (via USB)
        Source 3: Marantz DV6001 DVD player w/ MF V-Dac (via digital coax)
        * All sources...
        26 July 2009, 17:49 Sunday
      • Brandon B
        Question about DAC's/Jitter (for Jon?)
        by Brandon B
        Posted what I thought was a simplified explanation about sound quality in DD/DTS vs. PCM. Curious where I'm off vs. maybe the guy correcting me.
        My post:
        The response:
        My followup:
        Some more expert...
        15 May 2003, 09:40 Thursday
      • AwArEnEsS
        Using a Dac, no sound is coming from Pc or Tv
        by AwArEnEsS
        No sound from Pc or Tv using a Dac
        I have bought new speakers and ordered many cables and a Dac.This is my first Dac and it's a cheap one.
        It's not a usb Dac.I connected an optical cable to Pc and connected the other end of the cable to the Dac's optical input.Then connected...
        23 November 2024, 19:21 Saturday
        AURALiC Vega DAC
        This is one of those tests and write ups I've ben wanting to get around to for some time, but there always seems to be something more immediately urgent to distract me from the effort. Well, there still are those things, but I figured it's time to get this done because I'm...
        10 December 2016, 10:20 Saturday
