B&W703: Amp and Sub Questions
  • hieronimus
    • 5
    I wonder whether I should go for B&W 703, and if Rotel RB-1080 is ok for them.
    Should I consider a sub? There's an Infinity Kappa Sub on sale now, which sounded clear, but do I really need it for stereo?
    Roughly, the budget for the above is 5000 in USD.
    Enlighten me with ideas, please...
    Hieronimus
  • csuzor
    • 413
    I started with 2x 704 on a denon integrated amp, then 1x HTM7. After a listening session on Rotel (comparing integrated and separates), I immediately bought the 1068 and 1075, I didn't consider the 1080 because I need multichannel music. I then compared 704 and 703 and 804, and bought 2x 703, and later sold the HTM7, and bought a 3rd 703 for the center. It all sounds great now, so I've ordered a Sony CD/SACD dedicated player. Next, I may look at getting a digital Rotel (1077), which I'll need to compare when available here.
    If I had could have stretched the budget, I would have got 804 or 803, which clearly delivered "tighter" sound, "out of the box" compared to 703... But now with the 703 at home, my next speaker purchase will be HTM3 for the TV room, and then 3x 802 (if I get a promotion!) for SACD room (the garage).
    Oh, I forgot, yes, I'd like a sub, but with 5 large speakers and only music (no cinema) in a 30m2 space, I doubt I really need it...
    • hieronimus
      • 5
      Thanks for writing csuzor.
      Yeah, I'm very close to settling with a pair of 703 and Rotel 1070+1080 pre+amp. I am also limited with space, so I'll probably drop the sub for now.
      Any suggestions on a DVD player that gives good two-channel sound , but could also be used for watching movies on the stereo (no HT ambitions for now, but could expand later)?
      Hieronimus
      • grit
        • 580
        I've got a Rotel 1068 pre-pro, 1075 amp, 1060 DVD, and B&W 703s, 705s, HTM7, and ASW 700. Believe me, the 703s put out beautiful bass. You can easily get by w/o a sub, esp if you're not doing movies.
        If it's just music, the 803s SING! But that'll add about 2000 to your budget. 803s are better, but for the price range, the 703s are amazing!
          hieronimus, I ran a pair of CDM9NT's with an RB1080, and it produced a very good sound until I wanted to listen at high volume. In that situation my system just didn't cut the mustard, so I bought a sub and it made a big difference.
          As the 703's are the replacement model for the CDM9NT's (similar size, power and specs) I think that you'll find the same thing. That combination will provide good bass and plenty of mid/high range detail at low and moderate volume. So yes, the RB1080 is a good match for 703's.
          Whether or not you'll need a sub depends entirely on how much volume you require, for example whether you have dance parties, or a big room to fill, or just enjoy the occasional bleeding ear.
          • hieronimus
            • 5
            Thank you all for the feedback.
            I demoed several options at the dealer, and, for those looking into 705s, the price difference to 703s makes every sense. The 704 is somewhere in between, but closer to the 703. The 703s have superior volume, clarity and reachness to 705s, even with a sub. Especially the classical music is revealing of this. Between the 805D/S+sub and 703, still went for the 703. It's probably the larger box, and the mid-driver that make the difference.
            I decided for the 703s with the RC-1070/RB-1080, Marantz DV6500 SACD/DVD and Marantz ST-17 tuner. I skipped the sub for now.
            I played some old pop/rock music, and I was supprised to reveal the new details and colors in songs that I've heard so many times before. It's been quite an expirience :-).
            I still need to work on the positioning. The room is quite asymetric, with gallery in one part, 18ft tall there, and only 8ft at the other end.
            I still haven't got to the volume level issue, need to accommodate the neighbours/girlfriend with the "200W speakers in the neighbourhood" idea first :B .
            Last edited by hieronimus; 02 October 2005, 16:20 Sunday. Reason: the loud volumes issue
            Hieronimus
            • csuzor
              • 413
              Congrats, and welcome to the club! Nice choice.
              I agree, the 704 and 703 are quite close, and the 705 or 805 with a sub cannot compare to the 703. The FST mid and integrated bass driver make all the difference.
              For sacd, check out http://www.sa-cd.net/ and http://www.audioasylum.com/forums/hirez/bbs.html
                Good work hieronimus!
                • thyname
                  • 358
                  Congratulations hieronimious for your new purchase. I have B&W 703s in my mind when upgrading my 2 channel system in the future. I currently run Rotel RB-1080/RC-1070 combo with Rotel RCD-1072 cdp and Axiom M60ti speakers. However, not a long time ago, at some friend's home I listened to a pair of Totem Reference bookshelves (can't remember the series number) with a sub. Sounded awesome!! He also had a tube pre amp and a 2X30 wpc Passe class A power amp though. I was thinking of a pair of B&W 805s plus a sub instead of 703 with my current Rotel combo. Any thoughts or experiences?
                  • drpje
                    B&W 703 vs 704
                    by drpje
                    I am in the market for a new pair of speakers. I currently own the B&W CDM-1NT speakers. I would like a pair of floor standing speakers. I was thinking of purchasing the 703 or 704 speakers. My room is 22x11 feet with hardwood floors and concrete walls. I mainly listen to jazz CD's I plan...
                    29 June 2004, 03:47 Tuesday
                  • mafoo
                    DS7 Surround for 704/HTM7 front
                    by mafoo
                    I just purchased a 704/HTM7 combination for the front and am now considering my surround options. I haven't seen much traffic on the forum on the DS7 (seems most people go for the 705's). I'm interested in the DS7 for wall mount capability and the much shallower profile. Has anybody had good/bad...
                    22 November 2004, 19:53 Monday
                  • mafoo
                    704/htm7 to 804s/htm3s, what about surrounds?
                    by mafoo
                    I'm likely going to be trading up my 704/HTM7 combo for 804s/HTM3S. My surrounds are currently DS7's, and am wondering what I really have to gain for trading up to SCMS or DS8s. From specs, it looks like bottom end might drop from 80Hz +/-3db to 60Hz +/-3db. The primary of use of my surrounds is for...
                    20 November 2005, 11:44 Sunday
                  • CURATORIS
                    B & W 703 or 704
                    by CURATORIS
                    Hello
                    I am trying to buy a pair of speakers for a 2-ch system. Went to a dealer and listen to both, 703 and 704, and they both sound great.
                    My question is: which one of this speakers is more suitable for a 2-ch set up?
                    22 December 2006, 22:02 Friday
                  • JohnAng
                    Amp question - Arcam or Rotel for my 804 5.1 system
                    by JohnAng
                    I am looking at purchasing
                    B&W 804s fronts
                    B&W HTM4 cetre
                    B&W 705 rears
                    B&W ASW750 sub
                    i listened to this setup with an Arcam AVR300 amp
                    and Arcam DV79 dvd player
                    I realy liked the sound in 2 channel mode and since i won't be...
                    07 September 2005, 21:42 Wednesday
