X overs, the difference with and without
  • Bam!
    • Jan 2004
    • 2458
    Hi guys
    I am playing around with 1st order crossovers on my open baffles. Right now I have a wideband driver that rolls off at 8K's naturally at 6db/octave. I have a Supravox tweeter that cuts in at 5K, that is non directional.
    <<the sound>> it can get very forward and extremely dynamic in this configuration
    with a first order x over, being a .5 milihenri coil that (couldn't measure it ops: ) probably cuts the driver at around 5K at 6db / octave and then the tweeter kicks in at 5K that has a 5mfd capacitor.
    <<the sound>> better coherence and never gets forward, the sound always stays at the level of the speakers. Imaging seems a little more transparent. It seems a little more polite and refined then without though which is where my soft spot is. That is a compromise I can't accept.
    So, what are your experiences with and without x overs. Do you guys find they tend to suck the life out of the music, affect the weight of the sound, and lastly do dynamics really suffer ?
    Got a nice rack to show me ?
  • ToddAnisman
    • 142
    Hmmm...Kind of a loaded question....
    I have found in my experience of Contructing Mixing theaters that Crosssovers need to also have EQ's to smooth the "Bumps" out. If your room is small, I would say stay far away from a super complex monitooring system, you're never going to be able to get the pieces time aligned corrrectly - it's just too drastic to ask that separates be focused in together within 15 or 20 feet.
    let's put it this way...JBL spec's a 2-way system for a theater up to 500 people. Only then do they go to a 3-way. Tuning a 3 way is a cast iron B***h. Tuning a 2 way is no easy task either. I'd say fix your room first, then look into the expense of crossovers.
    -Todd A.
    • daniels
      Best midrange driver, 4-way?
      by daniels
      I have been building loudspeakers for quite some time now (fifteen years!?) and has usually been crippled by limitations of the listeners HiFi cave.
      But now I have been given some loose boundaries and I want to build a construction I have been working on for some years now.
      I have...
      13 January 2008, 17:48 Sunday
    • Lindahl
      Transmission Lines
      by Lindahl
      Started reading about transmission lines today and found this excellent reference. It sounds like, to find the ideal tuning, you need to balance the 1/4 wavelength resonance, fully stuffed, against the sealed box resonance, fully stuffed. I spent some time fiddling around, to see if I can come up with...
      14 January 2007, 18:43 Sunday
    • jeff_free69
      Monster speaker cable demo - is this fair???
      by jeff_free69
      I'm a beleiver in good quality speaker wires, just not fanatic about it ...
      So I'm passing thru Circuit City and they have a demo station set up for Monster speaker wire. You can switch between a 50 ft spool of their wire and one of some scrawny generic wire and hear the difference....
      20 February 2008, 13:21 Wednesday
    • servicetech
      Series Crossovers
      by servicetech
      What do you guys think about them?
      I tried a simple 6db/octave on my last project and it turned out pretty well.
      23 February 2008, 19:43 Saturday
    • Bing Fung
      Intel Cuts Prices, AMD to Ship Thoroughbreds....
      by Bing Fung
      Intel is going to have to slash more before I would consider a P4, even then I would want the 533Mhz FSB version with .09 micron core, which would most likely follow Intel's typical Flagship chip pricing and be somewhere around $1000 cdn anyway Price cuts never seem to help out the bleeding edge...
      15 April 2002, 16:50 Monday
