adcom with paradigm mini monitors
  • Turbo_sr
    • 3
    I am New here.
    I would like to get some advice on the adition of an outboard amp to my current system for two channel audio. I have a denon AVR 1905 and paradigm speakers. the main speakers are paradigm mini monitors. I was thinking of getting a used two channel amp but I am a student and have little money. I am also from canada so i've been looking at the cunuck audio mart and found an adcom gfa 555 for 500 canadian. Would this be a good idea or should I wait for and keep looking.
    THanks in advance for any help.
    Twin Moderator Emeritus
    • 16706
    If you get the Adcom, the Denon and your Paradigm speakers will be the weak link in the system IMO.
    • raider
      • 63
      Adcom
      turbo_sr;If its the mk II version of the gfa555 its not a bad price. :T
      I own two of those amps and running vertical biamping with real good results.
      I agree with aud19 as it will lead to more upgraditus :T
      It Is What It Is 8)
      • Turbo_sr
        • 3
        So the denon wouldn't work well as a pre/pro.
        • raider
          • 63
          It will work ok with what you have providing the denon has preamp outputs for the channels you intend to use to feed the adcom(i'm assuming your using the adcom for the mains)
          It Is What It Is 8)
          • Turbo_sr
            • 3
            The denon does have preamp outputs and yes i was going to use it for my front L/R.
            It doesn't sound like you think the mini monitors will benefit from the amp upgrade.
              • 16706
              Any speaker will have an improvement with better amplification. It just won't be as noticeable as on a pair of $2000 speakers for example.
              The old adage the chain is only as strong as it's weakest link comes to mind
              • raider
                • 63
                hence the upgraditus!!!!better amp,better speakers,better pre/pro(1098) etc.....
                It Is What It Is 8)
                  • 16706
                  Yup pretty much You'll hear the improvement that amp makes with your existing speakers and you'll start to wonder how much better it will sound with better speakers too. Then you'll ponder getting more and/or better amps, then a dedicated pre/pro :lol: Then you'll wonder if your sources are giving those components the best possible information... So you get a new DVD player and an outboard DAC. As your about to whip your credit card out for those you realize you're going to need better interconnects to translate all this information from your new DVD player to the pre/pro and from the pre/pro to the amp...
                  See what we mean..? :lol:
                  • pmeyer
                    Matching (Paradigm) speakers
                    by pmeyer
                    Ok, time to show my ignorance. Any help will be appreciated.
                    I know one should not randomly mix and match speakers. How does one determine is speakers are 'compatible'?
                    I have 4 Paradigm Mini-Monitors (circa 2000) along with a CC-370 and PS-1000 in a 5.1 configuration....
                    04 May 2007, 09:01 Friday
                  • ht_addict
                    Anyone picked up the new Paradigm Ref series v.3?
                    by ht_addict
                    With the addition of my new Rotel RMB-1095, I'm beginning to think its about time I upgrade my Paradigm Mini Monitors to the v.3 Studio line. I'm looking at 40's for front, 20's for rears and 470 for center. Looking for some input on anyone with the new line in their setup and what the cost was. Thanks....
                    16 August 2003, 16:47 Saturday
                  • ht_addict
                    OH the dredded buzz is haunting my setup.**SOLVED THE MYSTERY**
                    by ht_addict
                    My old setup:
                    Paradigm CC-350
                    Paradigm PS-1000
                    Rotel RMB-1066
                    New Setup:
                    Paradigm Studio 40v3
                    Paradigm Studio 20v3
                    Paradigm Studio CC470
                    Paradigm PW-2100
                    Rotel RMB-1095
                    08 October 2003, 07:27 Wednesday
                  • Jsapp
                    New 1055 Owner Next Upgrade?
                    by Jsapp
                    Hello all,
                    I have now owned my RSX 1055 for almost a month and have been amazed by the clean sound, easy configuartion and programmable remote. I am starting to think about saving for my next upgrade. How much and how long I need to save will depend on what I do so some advice from Rotel...
                    29 July 2003, 09:39 Tuesday
                  • mtodde
                    Anyone using RSX-1056 with Paradigm Monitors?
                    by mtodde
                    I have the upgrade bug and will be replacing my Polk (RT600 front, RT 2.5 rear, CS245I center) speakers in about a month. I am also considering upgrading my H/K AVR-525 and am considering the Marantz 7500 & 8500, the 1056 & NAD.
                    I'm curious about the results you've had with the...
                    15 February 2005, 23:22 Tuesday
