Saint-Saëns planar- AKA SMJ-40- time for a project now?
    • 16045
    #631
    Well, I must have been fast enough, because the last can of the Watco Danish Oil Golden Oak shipped yesterday! I'd been looking for it at other places that carry Watco products earlier this week, and no joy...
    Woo Hoo!
      • 16045
      #632
      Are you running out of denim fill as well? I have a giant box of it that I'll probably never get through if you want some.
      No, but for the Diapson "klone" I have been doing experiments with the help of ET, and he's sworn me to secrecy- but the R23 is being investigated more thoroughly, and it's a LOT easier to bend around a corner... in these chaotic times, a little experimentation is OK, yes?
      Been a busy morning with shopping errands and other tasks, but still making progress...
Name:	47 PR Installed M4's.jpg
      SL26R installed; M4 hardware on the back. After lunch the woofer installation will be finished, and some testing initiated.
Name:	48 Ready to Drop in.jpg
      These have 8-32 inserts and bolts on the woofer side, just because the Rampa vendor sent me the wrong part, but the screw diameter is nearly identical...
      You know, I really like the Dayton products from Taiwan and many other items from Taiwan... I'd be really disappointed if the current batch of geopolitical nonsense gave Xi the idea he can invade Taiwan without consequences.
      • Scareurpasenger
        Extra bamboo ply
        by Scareurpasenger
        I overbought some bamboo plywood. Is there any interest or need? It would need to be local pickup since this stuff is heavy! Roswell, ga
        14 August 2023, 19:53 Monday
        Exploring Common DIY Terminology - Planar Magnetic Transducers
        by technodanvan
        A planar magnetic transducer, also known as a planar driver, is a type of loudspeaker driver that uses a thin and lightweight diaphragm with an embedded conductive coil to produce sound. It operates based on the principles of magnetic induction. A planar driver consists of the below:
        • Diaphragm: The diaphragm of a planar magnetic driver is a thin, flat, and often rectangular or circular membrane made from a lightweight material such as mylar or a thin metal
        21 July 2023, 08:05 Friday
      • SoneNelson
        looking for 2way design -planar/isodynamic or fullrange +woofer
        by SoneNelson
        I am designing a custom 2 way tower from scratch and am at the point that I need some advice, This is my first Home Theater project. I have custom built dozens+ of subwoofer enclosures for cars, but custom crossovers and matching tweeter's with woofers/midranges is unfamiliar territory, I have over...
        08 June 2009, 01:24 Monday
      • crackyflipside
        Feedback on MTM planar enclosure/driver selection
        by crackyflipside
        Looking for feedback on this crossover I've been kicking around for my cousin who really wants a planar tweeter.
        It's an MTM with 6" Dayton RS150 mids and a planar tweeter. I want to use the Dayton PT2C-8 but it has an aggressive roll-off after 10kHz, which makes me want to redesign...
        13 July 2018, 20:16 Friday
      • biomed_eng_2000
        B&W Missing Parts?
        by biomed_eng_2000
        I bought three 602.5's (individually boxed) and they were what appeared to be factory sealed, they had typical B&W reinforced tape and even the copper staples.
        TWO of the THREE speakers were missing the manuals, port plugs, and speaker spike kits.
        I know my dealer will...
        13 August 2004, 10:46 Friday
