  • spadez
    • Jan 2010
    • 83
    #316
    The Xtreme SO sounds interesting. I looked at the pricing of the drivers:
    For a single TMW it would be around : $256
    For a single TMWW it would be: $340
    If I were to buy those drivers, would it be easy to adapt an existing crossover and enclosure to suit, or would it require extensive modelling and testing?
      • 16170
      #317
      I will have all the drivers soon. In a week or thereabouts I should have measured data on the RS270 and the NE180W in the proposed configuration for the SO. These are the white spots in the data picture at this time.
      The configuration for the Modula Xtreme and Modula Xtreme SO is based on TMWW. Top cabinet as described, the 1/2 cut ft PE cabinet- or build your own similar. Woofer cabinets are the 1 cu Ft PE Sub cabinets- per each 10" driver- or build your own similar. The most similar existing crossover would be that of the Ardent- you could use it to price out the approximate cost.
      What I strongly suggest is that you wait until I have the new midwoofer and time to test them and the RS270 in the existing enclosures I have on hand- that will probably get done next weekend, at the outside, the weekend after. Then I can have a preliminary crossover design pretty quickly after that, as it will be a full three way based on Duelund concepts, like the Ardent is, with adaptations as needed for the tweeter + waveguide behavior.
      If the driver performance looks good after testing, and the network cost looks acceptable, that might be the time for you to consider your purchase options.
      From my perspective, I know the RS70 is fairly low distortion (though not as low as the Scanspeaks, obvioiusly), and I'm pretty confident about it working well in the proposed alignment. But when I was a little kid, for a while we lived in Missouri, so from that I suppose I've got a bit of the "show me" attitude. The real question mark is the Vifa midwoofer. The impedance curve suggests a very low inductance motor design with lots of copper in the gap, that SHOULD have very low midrange distortion, and the amplitude response looks tunable.
      But until I have it in my hands, I certainly wouldn't suggest someone else commit their money, unless, I was in a Clint Eastwood kind of mood....
      "Are you feeling lucky?"
      • spadez
        • Jan 2010
        • 83
        #318
        It all sounds good, i'll be patient (I'm not feeling lucky )
        • spadez
          • Jan 2010
          • 83
          #319
          I cant bear to see this on page 2 any more
          Any updates, or are the Ardents the priority at the moment?
            • 16170
            #320
            Testing was done on the NE180W- see the Modula testing thread under Drivers Wanted- it looks as good or better as hoped. RS270 testing and some other bits later this weekend, then focusing on Ardents.
            • HeatMiser
              • 38
              #321
              Jon - do you still expect at some point to look further into the "slightly less Xtreme" TMWW tower with dual RS225s on the bottom? Or have the Xtreme variants discussed more recently sort of supplanted that?
              Not looking for a "when" as we all know you are Xtremely busy with a lot on your plate right now; just hoping for a tentative "if".
              Paul G
                • 16170
                #322
                The TMWW 2.5 way is very much in development- that's one thing the NE180W is being considered for, first of all, though the ER18RNX is still well in the running. Most of the crossover parts are on hand, too. This is planned to finish in time for the Northern CA DIY in late April.
                The Xtreme variant is a full three way with larger cabinet system and and more "Xtreme" drivers. I have all the cabinet materials on hand for the TMWW, and all the drivers- will be doing tests on the LF alignment this weekend. The weather isn't cooperating so I probably won't get around to setting up the saw on the patio this weekend.
                  • 16170
                  #323
                  A small update, regarding the TMWW, finished all driver measurements in cabinets yesterday, have data for starting the final crossover design- FCA alignment looks to be working out as modeled. Looks like it will be a nice small footprint slim tower, could work well in space limited applications- like my master bedroom!
                  • Jed
                    • 3621
                    #324
                    What I strongly suggest is that you wait until I have the new midwoofer and time to test them and the RS270 in the existing enclosures I have on hand- . . . .
                    My findings might mirror yours. IMO and for the money, I think the standard L26 is hard to beat below 150-200hz. For mid bass duties the RS270 is hanging with the Excel W26 and Scan Speak 26W, but has the added sensitivity which is a plus as well. I didn't test these all the same day, FYI.
                    Seas L26 85dbs
                    Seas Excel W26 :E
                    Here's the Scan Speak 26W 8 ohm:
                    Dayton RS270s
                    Seas L26ROY
                    Harmonic distortion
                    Last edited by theSven; 10 March 2023, 19:30 Friday. Reason: Update image location
                      • 16170
                      #325
                      Thanks, Jed!
                      • Paul Ebert
                        • 434
                        #326
                        The L26 does look quite impressive and is clearly a bargain. It's interesting that it does so well up against motors with copper rings.
                          • 16170
                          #327
                          My impression, Paul, is that the fundamental motor symmetry and gap saturation determine the low frequency distortion- but the copper rings control inductivity modulation and limit the rise in higher frequency distortion. One reason that well designed underhung motors can actually have decreasing distortion consistently with increasing frequency, whereas a simpler design may do well in the low and mid bass, but not so well in the upper midrange.
                          • spadez
                            • Jan 2010
                            • 83
                            #328
                            Hi Jon. Have you been able to do any more testing, if so, were the results postive?
                              • 16170
                              #329
                              All of the drivers and configurations for both versions of the Xtreme have been tested, and I consider them a "go"; final cabinets are in construction. The only thing I'm changing at this point is using the Scanspeak D2608 for both versions for now.
                                • 16170
                                #330
                                Back on Topic: Modula MT MkII PDF
                                OK, it's been hard to find time to work on this the last several weeks due to an onslaught of business travel, but for once this weekend, I'm not going anywhere next week and have had some time to finish the preparation. I'm also re-posting this at the beginning.
                                This is a download link on my .MAC site - click on this and the PDF should start downloading. It's only 6 MB, if you want to down load directly and not open in your browser, then right click and "save as".
                                Modula MT MkII PDF
                                Click image for larger version  Name:	MkII PDF Cover.jpg Views:	20552 Size:	89.3 KB ID:	854543
                                Last edited by theSven; 10 March 2023, 19:32 Friday. Reason: Update image location
                                • ultrakaz
                                  • Mar 2010
                                  • 17
                                  #331
                                  Thank you for the excellent writeup.
                                  • numberoneoppa
                                    • 535
                                    #332
                                    Great writeup, Jon. Makes me want more tools.
                                    It also brought up something I have been thinking about for a while: Toroidal inductors. I would imagine they would be superior to solenoid/coils in some way, but they're pretty rare in the DIY audio scene. Can you shed some light on this?
                                    :3
                                    -Josh
                                      • 571
                                      #333
                                      I second that. Thanks!
                                        • 16170
                                        #334
                                        :3
                                        Basically, they're more expensive to make. You have to use a material that is gapped by the binder, as otherwise the permeability is too high (such as if you had circular steel sheet plates). Also, the equipment to wind the coils is more expensive.
                                        Toroidal cores are very common in applications like switchmode power supplies, where the suppression of flux leakage from the core is a big advantage. Typically they're made with powdered iron or permalloy materials, though for some applications sintered ferrites are used.
                                          Excellent job Jon!
                                            • 16170
                                            #336
                                            Thanks for the kind words, guys. Now let's see if I can put something similar together for the Ardents - that will be a little bit bigger job, I think! It is underway, though.
                                            • mkc
                                              • Aug 2007
                                              • 37
                                              #337
                                              Hi Jon,
                                              Great work. Now, let's see where I can get these waveguides in europe...
                                              Best regards,
                                              Mogens
                                              • savage25xtreme
                                                • 305
                                                #338
                                                very very nice writeup!!
                                                I am awaiting a wave guide MTWW... is that in the books i.e. Modula MTWW in your signature? :T
                                                The Modula MT would make incredible surround speakers with the AWESOME off axis response.
                                                You should get a young pup to make the cabinets to your specs for free and send them to you.... hint hint, then you could concentrate on the true mastery.
                                                Gavin
                                                BAMTM Build
                                                • spadez
                                                  • Jan 2010
                                                  • 83
                                                  #339
                                                  Thank you for the write up, cant wait to have a read through it.
                                                  • Ray Collins
                                                    • 257
                                                    #340
                                                    Thanks Jon; you are very generous...
                                                    Ray
                                                    BENJAMIN FRANKLIN
                                                    • gazik
                                                      • 3
                                                      #341
                                                      Originally posted by mkc
                                                      Hi Jon,
                                                      Best regards,
                                                      Mogens
                                                      I'm also wondering where to buy these waveguides in Europe. If there is no success, maybe we could use wg-300.
                                                      And I wanted to ask you more skilled and wise, if this toroid http://www.europe-audio.com/Product.asp?Product_ID=7519 is usable for this purpose.
                                                      Peter
                                                        • 16170
                                                        #342
                                                        Peter
                                                        Probably would be, the DCR is higher, about double, but still reasonable- what's hard to know is where the core starts soft saturation and affects distortion. This I know for the Jantzen C-Core, and it's at about 250W- it is overkill for this project, but then it will have no more problems than an Air core, and it would be very hard to get an air core with the DCR.
                                                        • benchtester
                                                          • 213
                                                          #343
                                                          I have not be pleased with ferrite cores, although I have not tried the Jantzen C-Cores. With my low listening levels, I assumed that it was due to hysteresis as opposed to saturation. Any sage advice?
                                                            • 16170
                                                            #344
                                                            It's important to distinguish between Ferrites and powdered iron with binders or other powdered metal type cores which use binders to achieve a distributed gap.
                                                            Examples in the SMPS world are materials like Magnetics Inc. High Flux, XFlux, etc.
                                                            Ferrites are good transformer materials; can have pretty low core losses at moderately high frequencies, but normally the permeability is high and they saturate at relatively low levels. This is gotten around in applications like inductors or flyback transformers by introducing a gap (usually in the center leg of a three leg structure), but here the problem is that you get strong fringing flux around the gap which can introduce eddy currents in the winding- another loss, another nonlinearity.
                                                            Distributed gap materials such as powdered metal toroids can be adjusted in permeability by the shape of the magnetic particles used and the binders, to control the AL product, i.e, the inductance per turn, as well as the saturation level- lower mu means higher ampere turns can be sustained. Generally these materials have a soft saturation curve, whereas Ferrites kind of run into the wall, even gapped Ferrites.
                                                            But all this stuff is from my day job, and I'd rather not get into that here! :B
                                                            • spadez
                                                              • Jan 2010
                                                              • 83
                                                              #345
                                                              Could I get your opinion on what would compliment my setup? I have a double passive radiator 12" sub with plate amp connected to Onkyo 807.
                                                              Im wondering if there would be any benefit using the Xtreme version of the modular series since I already have a sub? I think having two woofers and a double passive rad might be a bit much even for me, and perhaps I should just go with a TMM?
                                                              Finally as a compromise, how difficult would it be for me to adapt your future plans of the TMWW SO Xtreme Modula speaker into a TMW, using exactly the same drivers, just a single woofer.
        The answer is dependent on the size of the listening room, distance from the speakers to listening position, and how loud you want the system to play.
        • spadez
        • Jan 2010
        • 83
        #347
        My listening room is fairly small (4M x 4M) but I want these to be future proof if I move. I want them to be able to go loud. The distance between the speakers and me is around 2M.
        If the future is guaranteed to be a larger room and improved electronics, go with a speaker having more Vd
        • Nigelb
        • Mar 2010
        • 3
        #349
        Adapting to a different Baffle size (yes I know....)
        My first post after years of lurking and learning!
        Ok So I have a question that may be considered as having an obvious answer.
        I have an existing enclosure with a similar volume but the baffle is 12.5" W x 19"H.
        I have calculated that the baffle step correction in the crossover for a 10" width baffle should be at 456Hz. For my intended baffle width it would be 365Hz. Without any change in the crossover it would presumably mean an approximately 4db hump between those two points?
        Now here is the dumb part-
        Can L1 be adjusted for the change or will it affect the entire crossover?
        • 16170
        #350
        It affects other parameters in the crossover, to some degree. A two inch wider enclosure will change the baffle step frequency, but I really don't see it putting a 4 dB bump in the response. (I could be wrong, it's happened before, I think it was July of 1999... ) :W Making it wider will lower the frequency at which it radiates into half space- easiest way to see the difference would be to use EDGE or Excel based BDS to compare the difference for the enclosure size. Then you could modify the transfer function from the original target function (in the PDF) using one of the free ware tools (from FRD consortium, for example) or using a standard crossover design program. What will most likely happen is a slight bump in the 750 Hz area, 1-2 dB. To some extent, you can tune BSC by a parallel R value to the main inductor.
        My first reaction is don't worry about re-tuning anything until you build and measure, but you can evaluate the results roughly in the manner shown above. Keep in mind that at the upper transition frequency, you tend to get an on axis bump, which can be accompanied by an off axis dip. In the end, without doing off axis curves and evaluating the power response, it's best not to "over react".
        • 16170
        #351
        Well, keep in mind there's a difference between the sub range and the woofer range. Many subs fall apart on harmonic distortion with rising frequency above 100 Hz due to inductivity modulation. The Scanspeak and RS270 have a fair amount of air moving capability, AND low distortion in the midbass and midrange, too.
        Changing from a TMWW to a TMW presents problems with regards to the voltage sensitivity and BSC. Dual drivers give 3 db coupling increase and 3 dB power draw increase, netting 6 dB greater output sensitivity for the same drive voltage. Going to a single woofer means scaling back the mid and tweeter sensitivity by 6 dB. Another factor to consider is that the dual woofer stack has different and complementary loading characteristics into the room- this gives both good boundary coupling at the floor and a taller source which helps to minimize floor bounce effects. If you only use one woofer, which do you use? You'll tend to lose out a bit in one parameter or the other, IME, which is another reason I'm pursuing this design as planned.
        Keeping the distortion low and the room interaction minimized is an important factor to helping a speaker pull a disappearing act.
        I'd say you'd be better served following the TMWW construction, and then using a conventional sub crossover setup down around 50-60 Hz, if you want to unload the deepest bass area and extend response into the 20's.
        Just my 0.02, of course, YMMV, etc. That's what I'm planning to do, though. I just haven't decided which of the oodles of sub drives I have lying around I'm going to go with- planning a push-push sealed stereo approach with LT in a smallish box, drivers radiating to each side. Maybe my BPD12's, if I can find them. 28 mm XMAX, and ginormous magnets.
        Nothing fancy or sexy, maybe a bit agricultural looking by todays standards, but plenty of Xmax.
        Last edited by theSven; 10 March 2023, 19:33 Friday. Reason: Update image location
        • Bent
        • Sep 2003
        • 1573
        #352
        I think that is terrific when you can actually misplace a pair of Blueprint 1203's.
        • 16170
        #353
        Terrifically absent minded! but then there is a pretty large block of drivers in boxes stacked up in my storage, the Blueprints just get lost among the Daytons, Aurasounds, Scanspeaks, Exodus, B&G, Fountek, Accuton and Stryke drivers. :W
        • savage25xtreme
        • 305
        #354
        come on TMWW!!!! :B :T ;x(
        need me to go on your business trips so you have time to pursue your passion? 8O
        Gavin
        BAMTM Build
        • spadez
        • Jan 2010
        • 83
        #355
        Thank you for the input Jon, Xtreme SO it is then. Im very eagerly awaiting the plans, but no rush because I feel guilty about the amount of information your giving us
        • savage25xtreme
        • 305
        #356
        it is very unusual in this world for someone to whole heartily devote so much time and effort and money, for free; which goes out to many of the great people on this forum. :T
        some day I hope to repay the favor, if at all possible.
        Gavin
        BAMTM Build
        • HareBrained
        • Jul 2008
        • 230
        #357
        You can send cash. I'm sure they would be very appreciative. :lol:
        John
        • savage25xtreme
        • 305
        #358
        I would donate drivers or x-over parts for a build, that's for sure
        in Jon's case his most restrictive resource is TIME.
        Gavin
        BAMTM Build
        • numberoneoppa
        • 535
        #359
        Is it only me confused about the renaming of this thread?
        -Josh
        • savage25xtreme
        • 305
        #360
        XE stands for Xtreme edition... I believe.
        Gavin
        BAMTM Build
        • jlaakso
        Modula MT XE floorstander
        by jlaakso
        The project started out a bit backwards or, literally, from top to down. I acquired the tweeters for a fair price and wanted to build something around them. One option would've been to start creating something of my own, but at this point it would've too much. Life and such sometimes gives directives...
        29 May 2013, 02:56 Wednesday
        • Martinsson
        Need help deciding on waveguide MT or TMM
        by Martinsson
        I am about to embark on my first speaker build so please bear with me when I ask what to some are very basic questions. I have read up a lot on this and other forums but I still have a couple of questions specific to my installation. The waveguides of John Marsh and John Krutke design...
        31 March 2011, 12:16 Thursday
        • knifeinthesink
        Modula MT XE waveguide profile for modelling in CAD. How can I get this?
        by knifeinthesink
        I'm trying to learn to use Rhino and CamBam with the CNC at the maker space I belong to and I'd like to model a baffle with a milled waveguide. The Modula MT XE has interested me for a long time so I thought I'd try this one.
        I know someone did exactly that and posted the project but...
        24 January 2014, 09:46 Friday
        • raygun
        Pellegreneacoustic or Diysoundgroup waveguide for Modula MT XE & Extreme?
        by raygun
        Hi guys,
        I'm considering building the Modula MT XE ( & hopefully a cheaper version of the Modula Extreme in future). The MCM waveguide is no longer available, but I came across pellegreneacoustic actually has a 6.5" waveguide that is listed to accept the SS D2608 tweeter - Item...
        16 October 2014, 00:05 Thursday
        Darth Modula MX Monitor
        by Evil Twin
        A new project for a “MaXimum Modula system is underway- actually, it has been in a low key manner for some weeks...
        All Modula’s are two way systems... this will be no different... except in the scope and the results.
        New waveguides sourced from vendors on the Galactic...
        23 August 2019, 08:38 Friday
