Welcome to HT Guide!
Well, a TMM is "officially" in the works, has already been modeled. But you're up against a problem with any 2.5 way TMM with regards to load impedance if your amplifier doesn't like 4 ohm loads.
Speaking of load impedance, hear's the plot on the MT's, taken just before I left for Sacramento yesterday to deliver these:
Red is the impedance curve in ohms, cyan is the phase. These are about as benign a load as you can imagine, even for tube amps. In the upper bass they do dip briefly to the 6 ohm area- this is a function of the driver impedance curve- this would probably be the limit for your Onkyo.
A two driver TMM will have about 1/2 the impedance - i.e, dip to about 3 ohms. Note the tuning on the bottom end- the impedance minima between the porting peaks is at about 36 Hz- this is the point of maximum port output. I normally shoot for an alignment that has an anechoic gradual taper/roll off from 100 Hz to box Fb, down about 6 dB at Fb, so that when people do the usual thing putting them a bit close to the wall than is acoustically ideal, they don't get all boomy and zaftig on you in the bottom end. THAT said, there is a substantial constituency out their that "prefers" zaftig bottom ends (on both speakers and women), and taste is taste, whos to say I'm wrong? Those people will find the bottom end a little light for their taste.
At my relatives, we put them where they wanted, next to the flat panel on a big furniture pieces, and things were just fine- was able to take off the big bass and treble boost their previous speakers had. And they were pretty amazed at how nice these sounded, even way off axis and in the next room. Put some Sting and Level 42 on, cranked it a bit, and big grins all around.
Mission accomplished. (something familiar about that phrase..... gotta figure that out). And Scot now will likely come to the Northern CA DIY in Roseville.
With regards to the TMM, I'm trying to arrange a collaboration between the doc and ET; maybe try something a little more heretical as an additional alternative- say, a 2.5 way with the same upper range drivers as this MT, but a Scanspeak W22 with flux capacitor for the 0.5 speaker, throw in a little more excursion and output capability, but keep the enclosure size down. Would that make it a TMW 2.5 way? Could be a new category....
