VituixCAD v2
  • kimmosto
    • 712
    #1306
    3.0.1.4 (2026-06-07)
    Main
    • Audibility warning and Audibility alarm lines added to GD & Phase graph.
    Impulse
    • Step and RMS curve smoothing reduced.
    • Single IR file export filename changed.
      • 1546
      #1307
      Just a note kimmo, the 'download' link in your signature points to VituixCAD2.
      • Reet
        How To: Mirror EQ with VituixCAD
        by Reet
        With VituixCAD, we have the ability to provide a mirror EQ function, that can then be passed to APO EQ for active processing. This allows for a speaker's frequency response to be fully compensated for without requiring many bands of parametric EQ.
        ​VituixCAD Process
        Connect each driver and EQ blocks in the crossover section as shown. Ensure that the active peak/notch filters are “shorted” so that only the G(f) block is directly connected to the driver. Three PEQ blocks are show,...
        26 December 2022, 12:26 Monday
      • Reet
        How To: VituixCAD Extended Impedance Model For Any Driver
        by Reet
      • Reet
        How To: Export Impulse Response from REW for use in VituixCAD (prior to 2.0.98.6)
        by Reet
        Update: Since VituixCAD 2.0.98.6, exporting IR using windowing as described here is no longer required. the impulse response can be exported directly, make sure to uncheck "normalize" on export. VituixCAD will automatically set "skip samples" to 1m (2.907ms) prior to the start time of the exported impulse response to maintain correct timing on import.
        REW can export the measured impulse response directly as MLSSA formatted text file, which can be used within the...
        25 December 2022, 16:28 Sunday
      • Reet
        How To: Filter Simulation with VituixCAD and EQ APO
        by Reet
        With meticulous passive filter design, it may be beneficial to hear the result before spending money on crossover parts and putting in the time to assemble the crossover. Fortunately, with VituixCAD and EQ APO and filter can be simulated digitally. This process can simulate multiple drivers simultaneously, one driver for each output on a soundcard, for example a 7.1 soundcard could simulate a stereo 3 way system utilizing 6 channels.
        Note that an emulated passive filter will reproduce...
        26 December 2022, 11:55 Monday
      • Reet
        by Reet
