SB29 DOS 28L Subwoofer
  • VilleKn
    • Nov 2014
    • 11
    Hello fellow diy and audio enthusiast!
    I am first time poster, but a long time lurker, and here to announce new project that I've started. It is a humble compact dual opposed closed subwoofer box using SB29SWRNX-S75-S drivers. At this point I've pinned down and purchased the drivers, amplifier and box design. Also the 24 mm birch ply in precut pieces have been ordered. The amp will be Crown XLS1002 that is good for 700 W to 8 Ohms bridged. EQ will be handled by a MiniDSP 2x4 that I've had for long time.
    The target for this sub is supplement a two way speakers with one 7" inch midbass (Seas E18RNX) for mostly music. We live in a condo, so I have to be mindfull of the neighbors meaning that SPL target is not high.
    I chose the SB29SWRNX driver mostly due to price and decent Xmax of +/- 11 mm. I could purchase these locally in Finland at ca. 125,00 €/pcs which seemed like a bargain. Also the drive is seems robust, is heavy and the color is black.
    https://sbacoustics.com/product/10in-sb29swnrx-s75-6-norex/
    Click image for larger version  Name:	10in-SB29SWNRX-S75-6.jpg Views:	15 Size:	23.2 KB ID:	949574
    The internal volume will be about 28 L. VituixCad simulation yields Qts 0,71 and Fb 47,7 Hz. With little help from Linkwitz transform Vituix shows the below curves. Max SPL is 103 dB at 40 Hz and 97 dB at 20 Hz within Xmax limits. With room gain this shuold meet the target. The curve below has sub sonic and LP filter applied.
    Click image for larger version  Name:	SB Acoustics SB29SWNRX-S75-6 SPL.png Views:	11 Size:	28.3 KB ID:	949575 Click image for larger version  Name:	SB Acoustics SB29SWNRX-S75-6 Excursion.png Views:	11 Size:	14.1 KB ID:	949577
    Box will be made out of 24 mm birch ply that I can source precut to specified size. The rest of the woodworking will be made at the local community college woodworking class. There will be more bracing running top to bottom not shown below.
    Click image for larger version  Name:	Näyttökuva 2023-10-23 205107.png Views:	11 Size:	20.9 KB ID:	949578 ​
    Click image for larger version  Name:	Näyttökuva 2023-10-23 205334.png Views:	11 Size:	10.6 KB ID:	949579
    Thanks for reading this far and more to follow.
    -Ville
    Last edited by theSven; 23 October 2023, 17:28 Monday. Reason: Remove duplicate image
    This appears to be a well conceived project- of course, in condo, 103 dB plus boundary reinforcement may get noticed by the neighbors. But my experience is that European flats and condos have much thicker and heavier walls than in America.
    It is fortunate you will not need your patio to do the wood working! I have tried to so similar things in the back of my Imperial shuttle, but the saw dust gets everywhere...
    • VilleKn
      • Nov 2014
      • 11
      The walls are ca. 20 cm concrete and the volume shall dependent on the master volume setting not set to max all the time.😉
      I have used the patio for woodworking before, but at this time of year it is +/- 0 degrees Celcius, dark, damp and raining water, wet snow or plain snow. These are not the ideal conditions for quality work.
      -Ville
      • VilleKn
        • Nov 2014
        • 11
        There is some progress to report.
        I made a few minor change to desing to simplify the construction and hopefully for enhanced looks:
        • The drivers are not countersunk -> just a trough hole to cut
        • The baffles are inset by 5 mm -> this will allow for a foam bad, with hole the size of a driver, and wrapped in fabric of some stylish cover to be installed (this is an idea in my head, not tested for funtionality).
        • Chamfers were reduced to just ca. 2 mm.
        The ordered cut to dimension birchply pieces habe arrived and passed incoming QA for square cuts and size tolerances.
        ​​​In the end, with the simplified woodworking and an available workspace in our building, allowed me to do the construction at home without too much complaints from my missus or the neighbours.
        Driver holes and the chamfers were cut with my trusty Biltema router.
        Glue up was done in our study. The bessey right angle clamp make it easy to glue pieces without sliding and in the correct place.
        Now the sub is fully assembled, and ready for sanding and finnishing. Test "woofes" have been sampled. I will post a picture later...
        -Ville
        • VilleKn
          • Nov 2014
          • 11
          One question: Should there be a small hole for pressure equalization to outside in these types of small closed subwoofer enclosures?
          • 1Michael
            1Michael commented
            Editing a comment
            No. That is not needed.
          Master of None
          • Jan 2014
          • 1665
          I would say no from the few sealed sub enclosures that I have built. Others who have more experience can share their thoughts on this. There is lots of sub building from years ago in this forum. You can try searching to see if this was asked previously. I've not seen it though from all the threads I have been updating through the year.
          Painter in training
          • VilleKn
            • Nov 2014
            • 11
            I found two sources to recommend a pin hole for small closed box subwoofers to allow pressure equalization.
            I Will make a small hole to the bottom and plug it with felt.
            1. https://www.linkwitzlab.com/Pluto/subwoofer.htm
            "Box construction The subwoofer box is assembled out of 3/4" multi-layer plywood. For maximum stiffness use glued and screwed butt joints or other wood joinery. The internal volume is 15.4 liter. No stuffing is used. A small pinhole equalizes the static air pressures inside and outside of the box."
            ​​​​​​2. https://sound-au.com/linkwitz-transform.htm#guidelines
            "The use of a small (say 5 mm) vent stoppered with felt to present a significant resistance to airflow is also a good idea - especially if the woofer does not use a vented polepiece (via the dustcap). This allows air pressure to equalise slowly, since you will have to expend considerable effort to make sure that the box has no air leaks. If present, any leaks may whistle or make some other equally undesirable noise when the subwoofer is in use. It is unlikely that you will be able to blame the dog for these noises (in case you thought you might get away with that excuse). "
              • 16205
              This technique has been used in the past by some manufacturers, and if a woofer has a cone and surround that is genuinely gas tight, I'd be inclined to endorse it IF it is likely that the system will be moved around, to different elevations. It's difficult to get a true gas tight enclosure, but not impossible.
                theSven commented
                Editing a comment
                Learning from the masters here on the forum!
              • 16205
              -Ville
              I sympathize with your issues for construction space- while I have lots of room now, the major build I did in 2019 was on the patio of my rented condo.
Name:	ArdentD Stereo SS.jpg
              • tktran
                • 703
                I was never quite sure what the late (and great) SL was concerned about.
                Perhaps he was referring to change in pressure difference due to cone movement? ie. volume displacement of subwoofers with large amounts excursion (Vd = Sd x excursion)​ will result in higher pressure as the cone moves in, and lower pressure as the cone moves out (Boyle's Law)
                Or was he concerned about static pressure differences of an airtight box vs outside box atmospheric pressure, which as you may know, varies slightly from day to day, and is dependant on temperature and humidity etc. That this would create unequal pressures between the inside of the box and the outside, resulting in the driver being displaced from it's rest position.
                I never left any hole, and never had any problems. And I have two 12" subwoofers per cabinet, and 2 cabinets in the room.
                But it would be interesting to see some empirical evidence to see what the effect would be.
                • Tyson
                  Upgrading SB29 to Illluminator Ring Radiators or get a better Mic?
                  by Tyson
                  I've got a SEAS Nextel w18, their 6.5 inch driver as my midrange and 3 peerless 7 inch HDS Nomex woofers in a pair of narrow towers. I've tried the Peerless HDS tweeters and they were too dry and light sounding for my tastes. I've been using the SB Acoustics SB29 as a replacement and I like the warmer,...
                  12 June 2010, 16:31 Saturday
                • CADman_ks
                  Woodworking advice...
                  by CADman_ks
                  Hopefully I'm not breaking any rules here, and if I am, admins please feel free to delete this or tell me otherwise.
                  The latest issue of Wood magazine arrived yesterday. I suppose that we could argue ad-nasuem about whether or not the guys at Wood magazine are "true" professionals...
                  12 January 2013, 12:39 Saturday
                • DeathMonk
                  Woodworking Rant
                  by DeathMonk
                  I make the most precise cuts. Throw out and peices that are even slightly off.
                  I start gluing a sub together last night that I am working on and notice that things are a little off (overhangs).
                  I measure the MDF and its almost 1/16" wider than 3/4". Same with...
                  16 July 2009, 11:20 Thursday
                • Bob Santos
                  Does the target market dictate the price?
                  by Bob Santos
                  I was doing a little thinking today about Pre/pro's, and Flagship receivers.
                  If you look at the B&K Ref 30, and thier 305, and 307 receivers the price differences just dont make sence to me.
                  The 305, and 307 use the Reference 30 as a pre/pro section. The 305 retails for just $200...
                  12 April 2001, 22:03 Thursday
                • Dotay
                  Question for the woodworking experts
                  by Dotay
                  I finally got around to buying a hardwood top that I will use to finish my subwoofer project. I purchased a piece of raw cherry that I'll use to cut a 20" diameter circle and I'm planning on using a 45 degree chamfer bit on the top edge. Here are a couple pics of the wood.
                  Images not...
                  03 March 2006, 09:33 Friday
