I can has Statements: Another Statement LCR build
  • jyqureshi
    • 141
    #91
    Thanks mikela, that thread is quite useful.
    • jyqureshi
      • 141
      #92
      Dampening the cabinets
      I'm still waiting for my DeWalt router to be delivered, so in the mean time i'm working on the crossovers.
      Today I ordered the following:
      For mid tunnel: 1" wedge foam
      For rest of the lining: 2" wedge foam
      Hope I made the right choices.
      • deewan
        • Feb 2009
        • 290
        #93
        I was just looking to order the foam yesterday but was wondering if the wedge foam works for the midtunnels. Most tunnels I've seen have flat foam.
        The Old Woods Theater
        My Various Speaker Builds
        Statement II Remix build
        • jyqureshi
          • 141
          #94
          hmmm, I did look for flat sound foam on their website but didn't find any.
          I am calling them and cancel the 1" foam, and order the flat one from parts-express.
            Hi Guys,
            Yes, the Statements speakers were designed with 1" flat foam. HERE (1.1 lb.)is a link to the foam on Foam by Mails website. However, I think the wedge foam would work with a little experimentation or the PE foam should be fine too.
            • jyqureshi
              • 141
              #96
              Hey Jim,
              Good to see you here, I ordered the PE foam though.
              But if one were to choose between 1.1lb and 1.6lb density foam, which would work best?
              Thanks again
              • Curt C
                • 792
                #97
                Which p/n did you order from PE?
                Originally posted by jyqureshi
                Hey Jim,
                Thanks again
                Curt's Speaker Design Works
                • jyqureshi
                  • 141
                  #98
                  This: http://www.parts-express.com/pe/show...number=260-525
                  I see one reviewer (with professional know-how) on it that doesn't like it that much.
                  So, that's why I asked Jim if 1.6 would be better over 1.1 if I were to buy one from FoamByMail.
                    I don't know if it'd be best but I think the 1.1 lb. foam is closer to the foam that the crossovers were developed with. I bought it locally at Hobby Lobby in the upholstery section.
                    HTH
                    • Curt C
                      • 792
                      #100
                      That should be fine. I wanted to make sure it didn't have a sealing layer on top. If you can blow through it, it should be acceptable.
                      • jyqureshi
                        • 141
                        #101
                        Statement Channel Construction
                        Here are some pictures of the progress so far:
                        I'm in your tunnel stealing your voices
                        Woofer Crossover:
                        Under side of the woofer crossover:
                        Mid Crossover:
                        Mid Crossover Underside:
                        Solder:
                        The extra space you see in the mid crossover board can be used for tweeter crossover.
                        So I ask the gurus to point out any mistakes in the crossovers.
                        J
                        • deewan
                          • Feb 2009
                          • 290
                          #102
                          I don't see any mistakes but I wanted to say I think you did a fine job with your soldering gun.
                          What gauge wire did you use on your crossovers?
                          • jyqureshi
                            • 141
                            #103
                            I think it's 18 gauge.
                            Don't know if 16 would make any difference.
                            I used this soldering station, for $30 it does a good job.
                            • deewan
                              • Feb 2009
                              • 290
                              #104
                              Thanks, I was just wondering since is didn't seem over the top heavy. I'm planning on using 16 gauge for my tweeter and midrange and 12 gauge for my woofers. I have 12 gauge running from my amps to my speakers so I just thought I would try to preserve that as much as possible.
                              • jyqureshi
                                • 141
                                #105
                                I guess you've got a high-end equipment, higher than mine.
                                • jyqureshi
                                  • 141
                                  #106
                                  A little problem
                                  After finishing the tweeter crossover, I tested one 5ohm resistor with my multimeter, here is the result:
                                  I took one loose 5ohm resistor and tested that:
                                  I also tested the 4.5ohm resistor on the tweeter board and it also shows 3ohms on the meter.
                                  The only reason I can think of is that I probably damaged the resistors during soldering :cry:.
                                  Is there anything I might be missing? Could both resistors be bad out of factory?
                                    Mills resistors can take a beating.
                                    Testing a component that is attached to others can throw off the reading.
                                    • TacoD
                                      • 1080
                                      #108
                                      Do not worry about it, with in circuit measurements it is hard to isolate one single component (several paths exists -> changes the resistance)
                                      • john trials
                                        • 449
                                        #109
                                        What is happening is: If you measure the resistance of one of the resistors in the tweeter xover, you are actually measuring that resistor in parallel with the series resistance of the other resistor and inductor. You will get a resistance measurement of approximately half of the resistor you are trying to measure (5ohm in parallel with (4.5ohm+DCR of inductor)).
                                        Basically, you probably didn't ruin the resistor during soldering.
                                        • jyqureshi
                                          • 141
                                          #110
                                          Thank you guys, and thank you john for explaining the reasons in detail.
                                          OK so there is 99 percent chance that the tweeter crossover didn't get ruined.
                                          I feel so much better.
                                          Hopefully I will get my foams, Router, T-nuts this week and then finish off the construction, but tonight I'll hook up the drivers and the crossovers and just test them out to make sure that the drivers make a sound.
                                          • DeathMonk
                                            • Jun 2008
                                            • 232
                                            #111
                                            I've gotten components burning hot and they all come out fine
                                            • savage25xtreme
                                              • 305
                                              #112
                                              Just be careful if you solder to the drivers... especially the tweeters
                                              Gavin
                                              BAMTM Build
                                              • jyqureshi
                                                • 141
                                                #113
                                                I will probably use the connectors. I think the ribbon tweeters come with the connectors.
                                                • DeathMonk
                                                  • Jun 2008
                                                  • 232
                                                  #114
                                                  Always use quick disconnects
                                                  • jyqureshi
                                                    • 141
                                                    #115
                                                    Hello guys,
                                                    I will be getting my new router sometime today, and I wanted to know which router bit I need to use to make "recess" for the drivers?
                                                    • savage25xtreme
                                                      • 305
                                                      #116
                                                      I used a whiteside 3 flute spirial up-cut with great results.
                                                      Note: the jasper jig is "calibrated" with a 1/4" diameter cutter. I prefer the 1/2 cutter and to calibrate the pin location/router screws with a set of calipers. for a much better driver fit. I was horribly unsatisfied with just putting the pin in the right hole and cutting a circle.
                                                      Gavin
                                                      BAMTM Build
                                                      • john trials
                                                        • 449
                                                        #117
                                                        A 1/4" diameter spiral downcut bit works great for the recess, creating a very clean edge. I also used that for my through holes. It heats up quite a lot when the cut gets deep (even when only cutting a 1/4 depth at a time). In the future I'm going to use a spiral upcut for the through holes, as it will clear out the particles better (and I'm not as concerned about a clean edge there).
                                                        • savage25xtreme
                                                          • 305
                                                          #118
                                                          that whiteside up-cut is razor sharp and I spin it pretty fast with my router and get extremely clean edges on the recess....
                                                          Gavin
                                                          BAMTM Build
                                                          • jyqureshi
                                                            • 141
                                                            #119
                                                            If I use spiral bit (up or down) for recess, how many passes will I need to make a wide enough recess so when I do a through cut, it will be covered?
                                                            • savage25xtreme
                                                              • 305
                                                              #120
                                                              with a 1/2 inch bit on the drivers in the BAMTM I had to make 2 passes to make a wide enough spot for the flange. Then I did the through cut and that ended up in the middle of the 2nd cut. obviously you will have to make more passes with a 1/4 bit. all of this depends on the dimension of your drivers... make it wide enough for the flange.
                                                              be careful with the 1 inch cut length when your baffle is 1.25 thick... you will have to go pretty slow and make sure the groove stays clear on your through cut.
                                                              Gavin
                                                              BAMTM Build
                                                              • jyqureshi
        • 141
        #121
        I have this upcut bit at the moment, will it work for both purposes, plus I bought this bit set from harbor freight, will the straight bits be of any help for recess?
        • jyqureshi
        • 141
        #122
        damn, I think I will return the upcut bit back to HD, and look for a more expensive one :/, don't want to mess up the baffles.
        • savage25xtreme
        • 305
        #123
        I don't think you will mess up the baffles, just have to pay attention and listen to how the router sounds, you can tell when its bogging down. vacuum out the groove after each pass. plenty of people have built Statements with a bit just like that one. I just prefer a more aggressive cut
        Gavin
        BAMTM Build
        • john trials
        • 449
        #124
        Your bits should be fine. Try them on some scrap MDF first, just to be sure. If you need different ones, try:
        Shop HValley Tools for premium woodworking tools, 3D printers, laser engraver and CNC Machines. Trusted Brands MLCS Woodworking and Eagle America.
        inexpensive bits, huge selection, plus free shipping.
        • jyqureshi
        • 141
        #125
        Thanks for the link for MLCS website, prices are quite reasonable there, I think I will go with them, I just want to make sure I get the right stuff and if I mess up I can blame myself rather than the tool.
        • savage25xtreme
        • 305
        #126
        I bought this set off amazon MLCS page.... I am not too impressed with how they did flush trimming my baffle to the cabinet. I had some sanding to do after. maybe all flush trim bits are like that though
        Gavin
        BAMTM Build
        • DancesWithBeers
        • 67
        #127
        I have used flush trim bits from several different manufacturers and they have differences with regard to how much of an offset there is between the bearing and the cutting edges. I'm not sure if this is just do to manufacturing tolerances with some brands, or if it is by design. Some cut too close, some not close enough, and a rare few seem to be dead on, as far as I can perceive.
        -DWB
        • jyqureshi
        • 141
        #128
        Hi guys,
        Just found out that I got two caps 54uf and 3.9uf each, instead of one 60uf cap. Will connecting them in parallel achieve 60uf?
        Hi guys,
        You should have a 56 uF and a 3.9 uF and yes, connecting them in parallel creates the 60 uF cap that is called for in the crossover.
        • jyqureshi
        • 141
        #130
        Yes, I meant to type 56uF. Thanks for the prompt response.
        I've been thinking of using the bottom of the Statements to hold the crossover board, which will require me to move the port to either back or front. I would prefer it to be on the front.
        What changes I will need to make to move the port to the front?
        There shouldn't be any changes required to move the port to the front/rear. However, I'm not a fan of front ported speakers. You greatly increase the chances of hearing "chuffing" noise with front mounted ports. I'd suggest you rear port it if you decide not to down fire the port.
        HTH
        • Curt C
        • 792
        #132
        FWIW, I concur with Jim on the front port. There will be no acoustic loss in the port output due to rear mounting, as we are firmly in the 4pi region at those frequencies, but any extraneous noise higher in frequency may be more noticeable with front mounting.
        HTH
        • jyqureshi
        • 141
        #133
        Thanks Curt and Jim, rear port it is then!
        • jyqureshi
        • 141
        #134
        In the Statement Center, are the following parts used for the rear port?
        Straight Tube
        Outside Flare
        Inside Flare
        Straight Tube
        Outside Flare
        Inside Flare
        No, I used a different port on the center. I used a PE 2 1/2" port (260-386) 7" long. There just isn't room in the center cabinet for anything larger and is works well.
        • sawdust
        What surround build for the Statements LCR fronts?
        by sawdust
        What would be a good surround build to go with Statements upfront? The issue is they need to be mounted on a wall behind the listening position, so Statement monitors won't work. Would a direct radiating design be best?
        Thanks.
        05 April 2010, 10:04 Monday
        • DocNice
        Statements II Build Thread
        by DocNice
        Budget:...
        Chuck's Statements 7.1 Build
        by impala454
        29 July 2008, 01:52 Tuesday
        • neilmaui
        Mini Statements build issues
        by neilmaui
        I thought it seemed to be going well.....numerous trips to Home Depot, acres of cut MDF, years of trawling through all the great build threads and its not until you embark on this project do you come up with your own issues! I read somewhere about a woodworking thread saying that a key thing is acknowledging...
        17 April 2013, 11:37 Wednesday
        • CAC3779
        Need Help Completing Statements II 5.2 Setup
        by CAC3779
        Hi Guys – glad to see this place is still alive and active.
        I’m dropping by to get some advice on how to complete my HT setup that I started down the path of building about, 5 or so years ago . I believe my old handle was Jblack03 (I think) but created this new account.
        02 November 2021, 07:07 Tuesday
