Rebuilding the Transcendent Sound Balanced Power Supply
    For those that haven't seen the original thread about the construction of this power supply HERE'S a link to that thread.
    After a month of living with the stock unit, I decided it was time to upgrade.
    First to go was the single residential grade receptacle and the silly outlet strip. The replacement would be a pair of hospital grade outlets, with differential noise filter caps.
    Since the stock chassis was originally destined to begin life as a pre-amp, the rear panel was littered with holes. Cutting more holes in the panel wasn't a good idea, unless something could be done to stiffen the chassis.
    I headed over to my local surplus store and dug around in their scrap aluminum bin. An appropriate piece of metal was purchased for the princely sum of $.85. I trimmed it to size, then cut rectangular openings for a pair of dual outlets. It was pop-riveted to the rear of the chassis.
    Those with Broadband can click HERE for the article
    Next I prepared the outlets for their new home with the addition of differential noise filter caps. And by removing the jumpers that bridge the individual outlets.
    To be continued.........
    Last edited by theSven; 17 August 2023, 18:05 Thursday. Reason: Update image location
    Here's a close-up shot of the new back panel. Note that my claim to fame isn't as a machinist. So the plan all along was to use standard outlet covers for the receptacles. Fortunately for me they hide a myrid of sins ....
    As one can see, there's plenty of room inside the chassis for the added receptacles and the differential filter caps.
    Article Link
    Last edited by theSven; 17 August 2023, 18:08 Thursday. Reason: Update image location
      I finally got my butt in gear to complete the rebuilding of this unit. HERE's a link to the website with lots of pics and more info.
      Before:
      After
      Last edited by theSven; 17 August 2023, 18:11 Thursday. Reason: Update image location
        • 1345
        Thomas, you dog! Just kidding - no apologies needed for the "cosmetic" work - hey, it's a power cleaner after all. Hmmm...I like that description - go ahead and trademark it. Anyway, excellent job as usual - I wouldn't expect less from you :T
          • 1532
          Excellent work as usual... perhaps a cluster of these would tame the power glitches I'm currently seeing in the primary power feed for equatorial ring turbo laser battery?
