Alternative to Mundorf M-Resist bifilar resistor
  • Audiophile100%
    • 132
    i'm searching an alternative to Mundorf M-Resist resistor.
    that's bifilar resistor technology
    could you suggest me same supplier ?
    does expotus uses this type of construction ?
    Special Resistor Specification Sheets
    thank you
    • 16205
    Unfortunately there's no way to tell from the information in the links if they use bifilar non-inductive wound configurations.
    There aren't many good alternatives to the Mundorf M-Resist series; I use them pretty much exclusively, and a number of high end manufacturers (Magico, for example) use them too. Mills resistors are non-inductive wound, but only rated for 12W, not 20W.
    • Audiophile100%
      • 132
      thank you jon.
      are these superior to m-restist ?
      Wirewound Resistors, Non-Magnetic, Non-Inductive, Axial Lead
      they have no inductance and no capacitance,
      the bifilar tech has capacitance element
      • dsrviola
        • 119
        Originally posted by Audiophile100%
        thank you jon.
        That looks like it's a Mills resistor. Mills is now part of Vishay. If you click on the MRA Datasheet link it comes up Vishay Mills.
          • 16205
          Vishay has some other film type resistors that are very low inductance, which I've used in amplifier applications. the thing for any resistor if you want to know what it does is look at it in detail on a network impedance analyzer like an HP 4192, which I use, and look at the ESL as well as determine the effective self resonance frequency due to parallel capacitance. At the impedances of speaker network resistors, the parallel C results in a self resonant frequency far, far above the operating range- ESL is usually more of a factor. But even then, it's often over emphasized considering what happens in the bandwidth up to 100 kHz. Just like wire coils versus foil coils- usually the best argument for foil coils is packing space and achievable DCR, not any inductance variation due to skin effect.
          One of the recurring questions that seems to be of interest to speaker builders is the matter of copper foil coils- does it make a difference, and is it worth the cost? Well, first off, I'll be the first one to say, "Well, try it, listen to them in your own projects....see what you think..." But some folks have
          • Audiophile100%
            • 132
            modified messagge
            • Audiophile100%
              • 132
              hi jon,
              how are you ?
              did you compared mundorf m-resist supreme vs jantzen mox ?
              • thirumalkumaran
                Alternative tweeter to Fountek Neo CD1.0 - Statements II
                by thirumalkumaran
                Hello all,
                Curious to build the statements II (back at it again) the drivers and crossovers are on order.
                Unfortunately, can't go with Meniscus kit, as import, tax & Customs will make it 2-2.5x the price to India!!
                I'm able to source woofer and midrange but the...
                03 September 2021, 02:25 Friday
              • Audiophile100%
                Jantzen wax coil and Mundorf cfc coil
                by Audiophile100%
                some of you have tried them?
                wax coil have a darker color than the Mundorf
                Mundorf are pink instead of the wax are orange, is the treatment that changes the color?
                color of the Mundorf seems the real color of pure copper, while that of the wax no, like oxidized.
                wax coil are...
                17 January 2015, 05:18 Saturday
              • lowark
                Capacitor and Resistor values...
                by lowark
                I am building Dennis Murphy's wmtw center and have a question on the capacitor and resistor total values. On the mid crossover bom there is a 7.5 and 50uF capacitor which need to equal 57.5uF. Also, there is 10 and 7 ohm resistor which need to equal 17 ohm.
                I understand on capacitors...
                22 December 2008, 11:55 Monday
              • Lurkalot
                Adding a Resistor to Crossover
                by Lurkalot
                I would like to add a resistor to the attached circuit to reduce the tweeter's output (I have received this info from the designer, Dennis Murphy).
                The resistor is to run in parallel with R1 & L1, as the last component in the tweeter circuit.
                08 January 2010, 09:17 Friday
              • Coconutout
                resistor damaged during soldering due to excessive heat transfer?
                by Coconutout
                im a noob at soldering and was touching the bare wire with the tip of the iron too long for several times to the point where the resistor was overheating. the resistor got hot enough that the paint on it was starting to feel sticky. once the crossover was complete, the sound of it seemed ok if a little...
                11 June 2010, 05:47 Friday
