Thanks cjd,
Can't wait to hear them, sometimes I wonder if I should have made the baffle thicker it is now 18 mm (3/4") on the other hand this would have made the volume smaller.
I did make some 12 mm rings to clue on the backside of the baffle so it is easier to install the drivers (mdf is just not the best material to use screws in) those plywood rings will also stiffen the baffle a bit. (I hope)
Twan
Twan
