Is this a crazy idea?
  • jacket_fan
    • Oct 2006
    • 83
    In the front of the theater I have a few problems I need to address.
    I have a pair of Magnepan 3.6s and a CC3 center channel. I have two DIY subs. And I have an amp (Cinepro 3k6SE) sitting on the carpet that drives the two subs. The CC3 sits on a speaker stand I made for the old center channel that is now upstairs in the family room. I would like to clean things up. I have been working on an idea to combine the pieces. I am looking at a combination Subwoofer, Amp stand, and Center channel stand.
    I have modeled up some concepts on how to have two 15 in sub drivers, a hole in the back to stick the amp and a place to house the center channel. I show the subs in a back firing, a down firing configuration and an opposing configuration one as well. I am assuming that the opposing configuration would be the better since there would be less vibration, but with something as big as this would end up being, mass may overcome the vibration and not be a problem. And I would prefer from an aesthetic stand point to have the drivers facing down or back. The drivers would be two more AV-15s from John at Acoustic Elegance.
    My thought is that I would use a sealed design for the subs to match the two existing subs and have a 3 cubic foot per sub volume. Would likely use plate amps to power them. These would also be run through a Marchand BASSIS for some low end boost and a BFD for equalization.
    The Cinepro amp has fans. I hate fan noise. And the fans do come on, especially when I listen to bass heavy music. So am wondering if I can do some acoustic trick inside the hole I am planning which could lower the fan noise. Either line the cavity with foam or attenuate some other way.
    As far as the speaker stand part goes, I leave the back open for the Maggie center back wave. I assume this is necessary, although have not contacted Magnepan about it.
    This way, I get two more subs, a way to locate and reduce fan noise and a less obnoxious speaker stand.
    The finish would be cherry and similar to the finish on the Maggies, the bracing I made for the 3.6s and the DIY subs.
    I would like feedback on whether this is a silly idea or constructive criticism on how to make this work.
    Rear firing sub
    Front view
    Back View
    Section cut
    Down firing
    Side firing
    Mark
  • brent_s
    • 89
    My first thought would be the effect of "extending" the CC3's effective baffle size. If Maggie intended for it to be free standing with appropriate baffle step, you're going to get 3-6dB of bass bloom below the step frequency since your cabinet essentially turns it into an inwall design.
    To help control vibration transfer to the amp, you could use foam blocks ala the Grama subwoofer isolation stands. Your nearest sporting goods store with paddle sports outfitting should sell the good dense stuff in various thicknesses.
    Any reason the amp can't be placed with the rest of the e-gear? I would also contact Cinepro about possible quiet fan swaps like folks do for pro amps.
    My quick .02.
    -Brent
    • john trials
      downward firing sub questions
      by john trials
      I'd like to get some more information regarding downward firing subs. I'm amazed that there isn't more information in Speaker Building 201 and/or The Loudspeaker Design Cookbook (or the web).
      I'd like to get some information so I can build the sub, but I'd also like to learn more about...
      28 December 2009, 09:27 Monday
    • vinceb
      Sub Placement and multiple subs (graphs)
      by vinceb
      After reconnecting my HE15 I have done a little experimentation with different placements and found that there is a lot to gain in my room from separating the subs. I found good interesting information on the web, specifically Nousaine's work on multiple subs and even better the Harman paper. My...
      07 March 2009, 21:31 Saturday
    • tommarra
      Side Firing Subwoofers to go under the Finalists
      by tommarra
      I am planning to build myself a pair of side firing subwoofers to go under Finalist speakers...you know for more bass output when used for HT application.
      Can some one provide me with feedback on the plans.
      Here is what I plan to use:
      I have to use a side...
      30 August 2013, 12:22 Friday
    • marquis
      Subs with a floor stander or stand mount?
      by marquis
      is there an inherent benefit to using a large floor standing speaker along with subs as opposed to just using the stand mount equivalent of the upper section of the same speaker with the subs crossed over a bit higher? It seems to me that in the first scenario you are basically just wasting the expense...
      18 February 2010, 00:44 Thursday
    • SilverJS
      Looking for opinions for DIY thin speaker on TV Stand
      by SilverJS
      Gents,
      Been a while since I've been here - have been too busy thoroughly enjoying my Nat P's I built 5 years ago! =)
      So I'm off to my next project. I'd like to build a nicely modern TV stand - see quick Sketchup model below. The shelf on the bottom will be home to a receiver...
      07 May 2012, 21:51 Monday
