I'd like to get some more information regarding downward firing subs. I'm amazed that there isn't more information in Speaker Building 201 and/or The Loudspeaker Design Cookbook (or the web).
I'd like to get some information so I can build the sub, but I'd also like to learn more about this...I'd like to UNDERSTAND the sub, not just build it. Any web links to informational pages would be great...the more physics involved, the better.
I plan on using Zaph's archived sub design: the RSS315HF-4 12" subwoofer, and a 2 cu ft volume cube.
Questions:
1) I mainly want to have the driver downward firing to hide the driver for aesthetics...am I going to adversely affect the sound by changing a side-firing sub into a downward-firing sub?
2) What is the minimum recommended clearance between the subwoofer driver and the floor (and WHY...what would happen if the clearance was only an inch or so...I'm not going to do this, I'm just curious)? The only answer I could find on the web was driver diameter/4 (or 3" of clearance in this case), but no explanation as to why.
3) Is it bad to have the sub firing at carpet, or would a hard surface be better? Most downward firing subs are sonotubes, which have a rigid baseplate that the sub is aimed at. Is there an acoustic advantage to the hard surface, or is it just for stability of the legs?
Questions:
